Variable tachometer warning
Old Dec 5, 2015 | 03:54 AM
optionray's Avatar
optionray
Default Variable tachometer warning
Can't believe I just noticed it after a year of driving. The yellow warning on the tachometer moves proportionate to the temperature of the oil, or at least appears that way. Pretty cool.
Old Dec 5, 2015 | 08:03 AM
jerrysmith2048's Avatar
jerrysmith2048
Lol yep.. I think bmw invented this first in the e92 m3.
Old Dec 5, 2015 | 08:14 AM
BlueFinn's Avatar
BlueFinn
I also noticed one day when the engine was not quite up to optimum temperature and I stomped it, two yellow circles appeared on the tachometer. I think one was at the initial rpm and the second at the current rpm?? They no longer appeared once the engine temperature was up.
Old Dec 5, 2015 | 08:23 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep, lets you know you're getting close to the suggested max rpm, which increases as the temp increases. Occasionally see it as I make a left across the 4 lane divided highway near my home. Usually brake hard at that point to enter another rural road on the right about 100 yards from where I get on. At heavy trafic times don't have much choice or I'd be waiting all day!
Old Dec 6, 2015 | 04:49 PM
sharpseadog's Avatar
sharpseadog
Default Smart Tach
During break in, it monitors mileage, then from then on changes with engine temp.
To Variable tachometer warning
