Gas
Old Dec 7, 2015 | 08:16 PM
davemiller's Avatar
davemiller
Default Gas
Can I burn regular gas in my 2014 z51 Why and whynot thanks
Old Dec 7, 2015 | 08:28 PM
pjitty's Avatar
pjitty
You can burn whatever you want in your car. The manual recomends 91, 93 octane. High compression engine...
Old Dec 7, 2015 | 08:30 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Dude, this subject has been covered so many times ............... Are you having a slow night ? The answer is no. Now may I suggest you refer to your owners manual. The answer is in there. Have a Happy New Year.
Zymurgy's Avatar
Zymurgy
Moderator
Can you. Yes, but not advised. Why not? Because you may void your warranty:
Use premium unleaded gasoline
with a posted octane rating of 91 or
higher. If the octane is less than 91,
you could damage the engine and
may void your vehicle warranty.
If heavy knocking is heard when
using gasoline rated at 91 octane or
higher, the engine needs service.
mustclime's Avatar
mustclime
11.5 to one compression ratio....you can, the computer will retard the heck out of your timing but you still might knock....not a good idea. You have enough money to buy buy the car but not enough money for the right gas???
Old Dec 7, 2015 | 08:32 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Do an advanced search in this forum! This subject has been discussed many times. [SPOILER] I would use 93 if available.
Old Dec 7, 2015 | 08:56 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Or, if in fact the op actually does own a full size drivable C7, all he need do is click on the link at the top of the page where the owners manual is. Personally, imho, the o/p is a
Old Dec 7, 2015 | 08:57 PM
1776DAVE's Avatar
1776DAVE
At 20 mpg city 29 hi way the 91 pays for itself...if you did use 87 mpg would likely go down 20% and it would be no fun to drive...
That said if you run out an only 87 was available from a gas can you likely could get by long enough to get to a gas station. But I am not an engineer. ... I an sure others with more information will come along and confirm or deny if that holds up...
Old Dec 8, 2015 | 12:04 PM
DCortez's Avatar
DCortez
No, because I said so!
That should do it
Old Dec 8, 2015 | 12:24 PM
VETJAZZ's Avatar
VETJAZZ
Check out this thread.
https://www.corvetteforum.com/forums...rade-fuel.html
Old Dec 8, 2015 | 12:27 PM
robert miller's Avatar
robert miller
Default ttt
I wouldn't want to run under 91 in the car. At 11.5 comp it will really cut down the power on the car that is if you get into the paddle and KNOCK starts in her.. Robert
Old Dec 8, 2015 | 12:43 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
The answer to your question is in the owners manual.
To Gas
