More HP for 2017?
Old Dec 8, 2015 | 05:05 PM
Mobil 1's Avatar
Mobil 1
Default More HP for 2017?
On the fence for leasing a 2016 1LT now or wait for the 2017 model year. If history is correct Chevy may up the HP by 25 or so. Any rumors out there?
The only options I was going to get was automatic NPP and the upgraded wheel size to 19" front and 20" rear but was told in order to get the bigger wheels I need Z51 or MRC.
Old Dec 8, 2015 | 05:21 PM
Larry/car's Avatar
Larry/car
The wheel/tire diameter is virtually the same if you get the base or Z51. I think there is a trim option where you can get the bigger wheels without MRC or Z51, other than a different look there will be no performance gain. The 2LT interior option has all the everyday goodies that I longed for. I went with the base car, would go that route again. As for horsepower, really have a hard time using the 455 horses I currently have, four plus seconds and you are through sixty mph.
Old Dec 8, 2015 | 05:24 PM
Walt White Coupe's Avatar
Walt White Coupe
Another option would be to buy the car with the stock wheels, buy a second set of 19/20 wheels/tire and sell the stock wheels/tires.
Old Dec 8, 2015 | 05:50 PM
Always Red Dave's Avatar
Always Red Dave
base stingray = 18" in front 19" inch rear
Z51 stingray = 19" in front 20" inch rear
Old Dec 8, 2015 | 06:16 PM
KWC6's Avatar
KWC6
On my base 2016 I have the 19 / 20... and its not Z51
Old Dec 8, 2015 | 06:18 PM
Mobil 1's Avatar
Mobil 1
Does it have MRC? The dealer told me it has to either have MRC or Z51. I don't want either.
Old Dec 8, 2015 | 06:36 PM
proexpert's Avatar
proexpert
I believe this is true. On the build and price site, you have to get MRC or Z51 to get 19/20 wheels.
Old Dec 8, 2015 | 06:45 PM
boraxman's Avatar
boraxman
I asked the same (HP) question sometime ago...Heres some speculation/
https://www.corvetteforum.com/forums...at-itself.html
Old Dec 8, 2015 | 07:23 PM
sTz's Avatar
sTz
I think that you'll see a hp bump, however, negliable. It's all speculation at this point. Accurate information will be available in about 4 months...
Edit: ... or five months
Old Dec 8, 2015 | 07:40 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Or..you can add 400 HP with a few modifications...and not worry about any increase..
Old Dec 8, 2015 | 09:03 PM
meyerweb's Avatar
meyerweb
On the build your own site, if you add the larger wheels the site also adds the MRC suspension. If you delete that, it also deletes the larger wheels.
I don't expect any HP bump. Fuel economy standards get considerably tougher for 2017. Adding HP while meeting those seems unlikely. In fact, I'd expect automatic Start-Stop to be standard to help in that regard.
Old Dec 9, 2015 | 08:25 AM
Walt White Coupe
That would really be annoying with the increased "start time" with the C7.
Old Dec 9, 2015 | 08:29 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
In before the "I got this from a very reliable source" comments start rolling in.
Old Dec 9, 2015 | 08:32 AM
glava2876's Avatar
glava2876
I believe that you can get the ZF1 option, which is for the Z51 rims and trim, but not Z51 suspension, tranny etc.
Old Dec 9, 2015 | 08:38 AM
rcooper's Avatar
rcooper
St. Jude Donor '15
ZF1 was dropped. the ONLY way to get the 19/20 set up is to order Z51 or MSRC on the base car.
But , as others have suggested, just go after market.
As for HP, I doubt that it would be a significant amount as CAFE regs. are getting more stringent for '17.
Old Dec 9, 2015 | 08:41 AM
AUTO_X_AL's Avatar
AUTO_X_AL
I believe that you must have the ZF1 option, which is for the Z51 rims and trim, but not Z51 suspension, tranny etc.
ZF1 ended in 2015. You know have to order the MR suspension to get the 19-20 combo. The Z51 isnt much more when you add the $3495 mag ride and $1195 NPP. I personally like the Z51 gearing better in the M7.
You may very well be better buying a set of wheels after the fact. You see take off wheels and tires for $1000-$1500.
Old Dec 9, 2015 | 08:47 AM
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
I heard a rummer that the 2017 will have less HP to meet Obama EPA standards. Better get the last good ones 2016. Do you remember what happened to the later C3's and C4's.
2016 will be worth more than 2017.
To More HP for 2017?
Old Dec 9, 2015 | 09:03 AM
Woodson's Avatar
Woodson
You'd never feel the difference of 25 hp.
Old Dec 9, 2015 | 10:29 AM
Walt White Coupe
I did what I suggested earlier. Bought base car with standard wheels and ordered 19/20's from GM parts.
Old Dec 9, 2015 | 10:38 AM
bbcb's Avatar
bbcb
is that the painted louver option ....wish i went that route ..
