PDR Testing
Old Dec 21, 2015 | 12:38 AM
AmmoVet's Avatar
AmmoVet
Default PDR Testing
All of these picts are from the Cosworth Software on my PC not from the incar video. They are snips of video to give you a feel for the software on the PC.
First three are out on the road enjoying the day. The last two are trying to see if I can use the track mode for Autocross.
The 2nd shot is a snip of the video showing the gps location on the left and the actual video shot out the window of the same location.
The 3rd shot shows the corners on the left and the car at corner 2-3 on the screen.
The 4th one shows my attempt to see if the track mode can be used for autocross and it is showing two different runs side by side. I need to learn how to synchronize them.
The 5th and final one shows the course I map out in an attempt to do autocross around the block. THe blue route shows the course with a different starting point then the end point. It is also comparing two different runs on the same course side by side in the blue and orange numbers at the bottom of the screen.
Need to play with it more but so far it is a cool toy!
