Seat height
Old Dec 22, 2015 | 02:52 PM
53348's Avatar
53348
4th Gear
Default Seat height
I am worried about the seat height in the c7. Can anyone post how high their stock c7 touring seat sitts off of the ground. And since the corvette is so low, how is it in a crash
Old Dec 22, 2015 | 03:08 PM
Zymurgy's Avatar
Zymurgy
Moderator
NHTSA has not tested the Corvette recently.
From the NHTSA FAQ:
10. How does NHTSA choose vehicles to rate?
Each year, NHTSA tests a sample of new vehicles predicted to have high sales volume or vehicles that have been structurally redesigned. Tested vehicles are purchased from dealerships across the country; the vehicles are not supplied directly to NHTSA by the manufacturer, a common misperception. Though NHTSA is unable to rate every car, all vehicles sold in the U.S. must meet Federal Motor Vehicle Safety Standards.
IIHS insurance loss data shows that the Corvette (2011-2013 - latest data available) does very well. In the top 1 or 2 for several categories. First chart is overall ratings for Sports cars. All others are Best Overall:
Old Dec 22, 2015 | 03:09 PM
53348's Avatar
53348
4th Gear
Default Seat height
How high does the seat sit off the ground. I am talking about the thigh portion of the seat. Not the h point.
Old Dec 22, 2015 | 03:20 PM
lgodom's Avatar
lgodom
Don't know the exact measurement, but the seat bottom is power adjustable up and down in front and rear to allow for drivers of different heights. It can also be tilted up and down in the front and rear. It's one of those things you really need to check out at your local dealer to make sure you can adjust it to fit your height and desired driving position.
Old Dec 22, 2015 | 10:01 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
^^^^^^^ This ! What works for one does not mean it will work for others.
Old Dec 22, 2015 | 10:03 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
In fact, I use both seat position buttons. One setting is for around town, the other slightly more reclined for long distance highway driving.
Old Dec 22, 2015 | 10:29 PM
Dif's Avatar
Dif
With the Driver seat raised to it's highest point, and all the way back, to Exit the car, the part where your butt sits is 10 Inches from the Ground.
The Front part of the Bottom of the seat, where your legs rest is a couple inches higher.
From it's highest setting it can go about 2 inches Lower
But as you move the seat forward to a driving position the whole seat goes up a slight incline raising the Whole seat.
So at any given setting, the part of the Seat bottom your butt rests on, can be between 8 - 12, maybe 13-14 Inches at the most, from the Ground.
Old Dec 23, 2015 | 01:16 AM
defaria's Avatar
defaria
Exactamundo! I just wish the buttons weren't that difficult to hit and that I'd only need to tap it instead of hold it throughout the seat motion.
Old Dec 23, 2015 | 09:39 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
If you're really worried about a crash, the seat height should not be the concern! Do you think the body frame is all that strong? Suggest you get a racing roll cage and a 5 point harness like I have in my Prostreet Rod!
Max Crash Protection, Roll Cage and 5 Point Harness
Old Dec 23, 2015 | 02:05 PM
53348's Avatar
53348
4th Gear
Would an suv override the corvette in a crash
Old Dec 23, 2015 | 08:01 PM
lgodom's Avatar
lgodom
If you're expecting the C7 to stand up to a full size SUV in a crrash then I'd look to another vehicle for safety. The height of the SUV vs the low height of. Corvette or almost any other sports cars isn't a good match. Corvettes hav come a long way in terms of safety, but a 5000+ Lb SUV vs a 3500 lb C7 doesn't come out favorably for the C7. It's one of those match ups you hope you don't see. If certainly isn't deterring my desires to buy a Z06, but is in the back of my mind.
Old Dec 24, 2015 | 01:39 AM
455230's Avatar
455230
Larger ones.....yes.....So would any full size pickup.
Old Dec 24, 2015 | 02:03 AM
checkur6's Avatar
checkur6
WOW! I bought my C7 (as well as all my other cars) to drive, not to crash. I drove a '70 VW Bus for 10 years (1970 to 1980) and did just fine. I am not going to drive my C7 constantly worrying about crash tests. Defensive driving with adequate separation and situational awareness.
Old Dec 24, 2015 | 04:29 PM
53348's Avatar
53348
4th Gear
Default Seat height
I am going to purchase my 2014 c7 corvette. Has 1000 miles. I have consitored what you said and will buy one for my 4th car
To Seat height
