Moderate?
Old Dec 29, 2015 | 08:24 AM
L8ter's Avatar
L8ter
Default Moderate?
The owners manual says :
For the first 322 km (200 mi):
. To break in new tires, drive at moderate speeds and avoid hard cornering.
Hard cornering I understand, but what do you consider moderate speeds?
Old Dec 29, 2015 | 08:25 AM
Kracka's Avatar
Kracka
Basically, don't drive the car like it's your getaway vehicle after robbing a bank Typical highway speeds are no problem.
Old Dec 29, 2015 | 08:43 AM
Don't do burnout a or doughnuts in the parking lots.
Old Dec 29, 2015 | 08:46 AM
dvilin's Avatar
dvilin
Drive it like it is a Ford Focus not a Corvette.
Old Dec 29, 2015 | 09:18 AM
\Boost Monkey/'s Avatar
\Boost Monkey/
The faster you car is traveling, the more the wear by the friction/shear forces and higher heat on the tires from the higher speeds. This car is capable of pretty damn high speeds (namely 150mph+ for the case of tire wear), and as such they are basically telling you to not drive at these higher speeds while the tires are still new.
As an EXTREME example:
A Bugatti Veyron Super Sport uses special Michelin tires and although softer like a race compound tire to handle high G's, at 250mph sustained the Michelin tires will last approximately 15 minutes before they are completely shot and need to be changed out to new tires.
Old Dec 29, 2015 | 09:47 AM
juanvaldez's Avatar
juanvaldez
My wife's Ford Focus will do 155!
Old Dec 29, 2015 | 11:46 AM
Patches's Avatar
Patches
If I am going slower than half the traffic around me and faster than the other half, I consider this moderate speeds. I have been told that keeping speeds below ~65 mph, no panic stops and no corner speeds that cause the tires to squeal for the first 500 miles is a reasonable break-in. Here's what Tire Rack recommends on their website:
"Tires are comprised of many layers of rubber, steel and fabric. Due to these different components, your new tires require a break-in period to ensure that they deliver their normal ride quality and maximum performance. As tires are cured, a release lubricant is applied to prevent them from sticking in their mold. Some of the lubricant stays on the surface of your tires, reducing traction until it is worn away. Five hundred miles of easy acceleration, cornering and braking will allow the mold release lubricant to wear off, allowing the other tire components to begin working together. It is also important to note that your old tires probably had very little tread depth remaining when you felt it was time to replace them. As any autocrosser or racer who has tread rubber shaved off of his tires will tell you, low tread depth tires respond more quickly. Don't be surprised if your new tires are a little slower to respond (even if you use the exact same tire as before). Their new, full depth brings with it a little more tread squirm until they wear down."
Old Dec 29, 2015 | 11:30 PM
meyerweb's Avatar
meyerweb
Don't overthink it. Drive it like a normal car would be driven on public roads. Vary speeds and rpm, including both accelerating and decelerating in gear to load the rings, and don't worry about it.
Old Dec 30, 2015 | 12:34 AM
WMark's Avatar
WMark
St. Jude Donor '11
I had 30 miles on my '16 when I went on a 200 mile club trip. Trip included I-10. As meyerweb says, vary the speeds, etc. Now have close to a thousand (oil change at 503 miles) and everything is hunky dory.
Enjoy! One heck of a car.
Old Dec 30, 2015 | 07:12 AM
C7Joy's Avatar
C7Joy
There you go!
Old Dec 31, 2015 | 08:30 PM
INTHERED's Avatar
INTHERED
Originally Posted by L8ter
The owners manual says :For the first 322 km (200 mi):. To break in new tires, drive at moderate speeds and avoid hard cornering. Hard cornering I understand, but what do you consider moderate speeds?
In my opinion I think that statement is to guard against people trying to pull a 1G turn right off the dealer lot before the tires are fully scrubbed in.
To Moderate?
