Heated Seats ???
Old Jan 9, 2016 | 07:27 PM
dvilin's Avatar
dvilin
Not the greatest but good enough.
Old Jan 9, 2016 | 08:02 PM
-HAIRBALL-'s Avatar
-HAIRBALL-
Mine get very warm. My wife is always cold and on Thanksgiving she turned on the seat warmer on the way home and actually had to turn it down because it got too hot.
Old Jan 9, 2016 | 08:13 PM
HANNY's Avatar
HANNY
I would assume they use a similar heater element in all gm cars, if that's the case I would think the only difference is the padding, might get better in time when the seat starts to wear a little?
Old Jan 9, 2016 | 08:59 PM
chefcg1's Avatar
chefcg1
C7 of Year Finalist (performance mods) 2019
They warm up , it just takes longer. Hell my BMW seats would burn you on high, so i'm okay with the slower heating.
Old Jan 10, 2016 | 12:25 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
But it's not just the foam "padding" that is under the heating elements it's a thick open mesh directly under the leather and above the heating elements that is used so the small fans can spread and circulate air for cooling. May be similar construction in other GM cars IF they have cooling, see pic in my post # 5. Lear makes the seats for Corvette and probably some other GM cars but not all. They also make seats for Porsche and Ferrari.
Guess while you wait for ~10 minutes to feel significant heat you can think now it helps in the hot summer!
I do have to go from 3 to 2 or 1 bar but that takes about 10 to 12 minutes when I'm half way where I'm going!
Old Jan 10, 2016 | 02:24 AM
only9balls's Avatar
only9balls
Haha! same here... my 335d would bake your biscuits, and heated up by the end of the first block. These take a long time to heat up, but are sufficently warm eventually.
Old Jan 10, 2016 | 08:02 AM
rrsperry's Avatar
rrsperry
Since I've only had the car a month and a 1/2, I don't have a lot of time in it. But... My Mini Cooper (BMW) was nuclear. You literally had to turn them down from high by the time you reached the end of my 1/4 mile driveway.
With this car, I'm getting heat of the vents, and the cold red line is almost gone before you can start to feel anything from the weak seats...
I might actually might do some investigation on this... I'd bet that there is a resistance module in the switch that limits current to the seat heaters...
Old Jan 10, 2016 | 08:17 AM
JerryU's Avatar
JerryU
This is my 3rd winter, see my post #5, that's the answer! It's a compromise for what was needed to have cooling in the summer. It gets warm, just takes 10 to 12 minutes!
Old Jan 10, 2016 | 08:53 AM
nytrorcr's Avatar
nytrorcr
May be slower to heat up but not that I have noticed, I allow my car to heat up before leaving the house so seats are just right when I leave.
Old Jan 10, 2016 | 09:33 AM
Walt White Coupe's Avatar
Walt White Coupe
I'm so glad we have something really important to complain about. Not!
Old Jan 10, 2016 | 04:26 PM
CETA 256's Avatar
CETA 256
Mine has suede inserts and they do not heat like our cadillacs. It is luke warm at best IMO. Otherwise, love this beast.
Old Jan 10, 2016 | 05:16 PM
Z06 1of38's Avatar
Z06 1of38
Old Jan 10, 2016 | 05:18 PM
  #33
joemosfet's Avatar
joemosfet
I turned mine on to 3 and couldn't feel anything. I asked the service department to take a look at it, while I had it in for oil change.
Old Jan 10, 2016 | 09:20 PM
  #34
JerryU's Avatar
JerryU
If no heat after 10 minutes at 3 bars there is a problem, but it takes that long!
Old Jan 10, 2016 | 09:28 PM
  #35
joemosfet's Avatar
joemosfet
Funny thing is, I decided yesterday to buy GT seat upgrades and will be pulling out the seats and might have been able to find the problem myself. Oh well.
Old Jan 10, 2016 | 09:31 PM
  #36
owc6's Avatar
owc6
Originally Posted by dataporter
I have the micro suede and I think my seat heaters work fine.
Old Jan 10, 2016 | 10:00 PM
  #37
Kyflyer's Avatar
Kyflyer
3LT, 2014, purchased November 2013, heated seats were pathetic then and still are. Small problem in an otherwise great car.
To Heated Seats ???
Old Jan 11, 2016 | 12:17 PM
  #38
Ernest_T's Avatar
Ernest_T
I find the seats get warm enough to move the setting down to low after several (15) minutes. It takes longer to heat the Corvette seats than our Cherokee's, but those seats get so warm you can't use them above the low setting. They get really warm, really fast.
Old Jan 11, 2016 | 10:45 PM
  #39
wgood's Avatar
wgood
Originally Posted by joeman2573
All my cars have heated seats and by far my experience with my c7 and my new Z06 is they can hardy be described as heated. I would say they are Luke warm at best. Anyone feel the same and is there a fix ?
You are right !!! My 2005 Pontiac Bonneville GXP has heated seats and they are really warm such that I sometimes turn them down or off !!! That's the problem because earlier seats had problems with getting to hot or catch things on fire !!! Wayne
Old Jan 12, 2016 | 12:44 AM
  #40
Rich Farr's Avatar
Rich Farr
Default Same Problem With 2014 Cadillac CTS
Seats take very long time to heat up - real pain in Canada - only warm when you arrive. Cooling is really pathetic too. Super hot days barely any cool air. Dealer told me okay as fans worked and no codes showing. 2010 C6 heats up in one minute!
