Engine Light
Old Jan 11, 2016 | 09:40 PM
SugarGrl's Avatar
SugarGrl
Default Engine Light
Stupid engine light came on today, solid not blinking. Took it to the dealer who read the code and said car was in the wrong gear. Doh, it was not! Anyway he cleared the engine light. Sorry didn't get the code for you guys but has this ever happens to any of you? Car ran fine while the light was on. Still love my Punkin, she can do no wrong.
Old Jan 11, 2016 | 09:47 PM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
If it happens again and you have On Star press the blue light and ask them to tell you what the code number is and what it specifies is wrong.
Old Jan 11, 2016 | 11:31 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
The car was in the wrong gear. What does that even mean? Why would there be a check engine light for that?
Old Jan 12, 2016 | 12:29 AM
, and maybe time to find another dealer to work on your car.
Old Jan 12, 2016 | 01:32 AM
Mobil 1's Avatar
Mobil 1
Probably a anomaly but if it's a automatic it could be a problem. Meaning the computer commanded a gear (let's say 3rd) but the trans stayed in 2nd for a bit longer. Possible shift solenoid etc.
The dealer should have been able to see the data when the error occurred as it gets stored. Everything from MPH, eng temp, speed etc.
Clearing the code is fine but if it happens again it will have to be addressed.
Old Jan 12, 2016 | 04:03 AM
Makitso's Avatar
Makitso
http://myautomatictransmission.com/t...uble-codes.htm
http://www.obd-codes.com/p0730
Old Jan 12, 2016 | 07:44 AM
SugarGrl's Avatar
SugarGrl
It's a manual transmission and the car was driving and shifting fine. I'd love to get my hands on one of those plug in analyzes, wonder how much they run?
Old Jan 12, 2016 | 07:55 AM
JameyTurner's Avatar
JameyTurner
Too Much Fun
Cheap, especially if you just want it to tell you the code. They can be picked up at Wal-Mart or any auto parts store.
Example: there are cheaper ones out there besdies this one.
http://www.walmart.com/ip/Innova-303...eader/47403605
Old Jan 12, 2016 | 08:01 AM
DBLXX's Avatar
DBLXX
I've been using a WiFi OBDII code reader bought on Amazon for $11 bucks the past 4 years.
Order one, plug it, synch it - done.
Old Jan 12, 2016 | 09:42 AM
SCorvette08's Avatar
SCorvette08
here is a trick that works once you see a code light on and you feel all is well and OK just open both doors and walk away with your fob out of range that tells the computer to reset
the factory delivery museum guy when you pick up your car gave me this tidbit hope it helps i used this method once and it cleared the light
Old Jan 12, 2016 | 10:06 AM
Red C8 of Jax's Avatar
Red C8 of Jax
Really wrong gear, find another dealer.
Old Jan 12, 2016 | 06:47 PM
SugarGrl's Avatar
SugarGrl
You guys are the BEST! Thank you!
To Engine Light
