Removing C7 Engine Cover
Old Jan 14, 2016 | 01:14 PM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
Default Removing C7 Engine Cover
I need to remove my engine cover to have some graphics applied. Is this a big job? What all is involved?
Thanks...
Old Jan 14, 2016 | 01:28 PM
Scoobydoobydoo's Avatar
Scoobydoobydoo
Which engine cover ? Are you talking about the plenum cover ? If so its no biggie, do a search here as multiple guys have removed it
Old Jan 14, 2016 | 03:02 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
The covers just pull off. The plenum cover you unbolt, undo the lines attached through it then clip the ties holding the spark plug wires down. There really aren't any surprises to it.
Old Jan 14, 2016 | 03:22 PM
LIE2ME's Avatar
LIE2ME
So the plastic "Corvette" side covers just pop off? and what sort of lines are running through the plenum cover?
Old Jan 14, 2016 | 03:43 PM
Scoobydoobydoo
The Corvette covers just pull off. Grab from the top to lift that side off first then the bottom will come undone.
Old Jan 14, 2016 | 04:04 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
I just looked, there's just a sensor you need to unplug. Just pull the tab and disconnect it. The lines run through the covers below the plenum. Once you have the covers off, it's pretty easy to figure out what needs to be unbolted, snipped and unplugged.
Old Jan 14, 2016 | 04:44 PM
bbcb's Avatar
bbcb
Originally Posted by lie2me
i need to remove my engine cover to have some graphics applied. Is this a big job? What all is involved?
Thanks...
why ??
Old Jan 14, 2016 | 04:49 PM
TEXHAWK0's Avatar
TEXHAWK0
There is a post with detailed photos if you do a search.
Old Jan 14, 2016 | 04:52 PM
LIE2ME's Avatar
LIE2ME
Actually, I did a search, but the forum search engine never works for me. I put in key words and end up with scores of postings going over periods of years that in many cases has nothing to do with the subject I am trying to look up. Very frustrating....
Old Jan 14, 2016 | 04:55 PM
fumbling's Avatar
fumbling
I agree, I've searched using terms like "engine cover off" and have never seen a pic of the engine in an actual C7 with the plastic cover off.
Old Jan 14, 2016 | 05:20 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I searched "engine covers" and got this: https://www.corvetteforum.com/forums...r-removal.html
That should help you.
Elmer
Old Jan 14, 2016 | 05:28 PM
pkadams's Avatar
pkadams
Many engine "dress up kits" include a graphics cover for the plenum that is a thin plastic cover that fits over the plenum and attaches with double sided tape. The fuel rail covers of course just snap off. If you look at the picture in my signature, the plenum graphic is a cover that fits over the plenum.
Old Jan 14, 2016 | 09:50 PM
TEXHAWK0's Avatar
TEXHAWK0
Elmer
That's the one I was remembering...good photos of each step.
You are correct that sometimes the search does not bring up exactly what you are looking for as the first item..often you have to look down the list a page or two to find exactly what you are looking for.
Old Jan 15, 2016 | 03:09 PM
LIE2ME's Avatar
LIE2ME
Elmer
Thanks, Elmer. This is exactly what I need...
To Removing C7 Engine Cover
