Windshield Washer Fluid
Old Sep 30, 2018 | 12:19 PM
  #41
Thunder22's Avatar
Thunder22
Originally Posted by joemessman
Some of the fluids contain chemicals that will etch and stain the transparent roof tops.
First i'm hearing of it on here, i even did a search and this was the only thread that came up, I wouldn't worry about it unless you're using acid in your washer fluid.
Old Sep 30, 2018 | 04:10 PM
  #42
jimmbbo's Avatar
jimmbbo
Plastic and ammonia seem to be a bad combination.
I searched CF C7 General Discussion forum for "ammonia" and a five minute review of the first 4 pages out of the 497 that turned up yielded:
https://www.corvetteforum.com/forums...arent-top.html
https://www.corvetteforum.com/forums...cleaner-2.html
https://www.corvetteforum.com/forums...crazing-2.html
https://www.corvetteforum.com/forums...d-feeding.html
https://www.corvetteforum.com/forums...color-top.html
Old Sep 30, 2018 | 04:19 PM
  #43
Thunder22's Avatar
Thunder22
just reading the first link it says the cause is the clear coat, not the cleaning products.
the 2nd one is just about which cleaner is best, nothing about causing damage.
3rd one again is crazing from the clear coat and heat
4th one says don't over think it clean it like rest of car
5th is crazing again from heat and clear coating
so i'm still saying don't worry about it, it's not the windshield washer fluid causing any damage. (which non of those links reference at all)
Old Sep 30, 2018 | 08:22 PM
  #44
aj98's Avatar
aj98
Originally Posted by nmerhaut
I use what ever the discount store has on sale.
Sometimes do the more expensive stuff, but not often.
ammonia?? thats in windex. Never smelled it in any off brand washer fluid..
