Options for Daily Driver C7
Looking to buy a daily driver C7.
I have decided upon a 2LT coupe and A8.
I am getting Magnetic Ride and a pretty loaded car.
The question is Z51 or not. This is not a which is better blah blah thread.
Car will never be tracked. Ever.
I will be putting A/S 3s on the car upon delivery and it will be driven in all types of weather here in NJ (cold, rain, light snow, etc...)
I'm wondering if the EDiff on the Z51 would help the car in inclement weather as compared to the standard cars mechanical diff.
Can someone chime in on that point alone?
Greatly appreciated.
-has the better looking rims
-rims come in black
-has NPP
- tighter suspension
I wanted my car to handle more like a sports car on the roads. had nothing to do with tracking. Probably dont need the better brakes, or dry sump oil.
I would get NPP regardless and this is not a $$$ issue.
The question really just is will the electronic differential be better in inclement or cold weather compared to the standard cars mechanical differential?
Nothing else in the Z51 has any bearing on this topic.
This is a legitimate driveability and safety question.
Now if you plan on turning off all traction aides the e-diff might be slightly better as it is computer controlled - good luck with driving a C7 in snow without traction management.
As an all weather car, the Base suspension without MSRC due to its higher sidewall tires will give by far the best performance in the snow if you drop the tire pressure to about 25 psi
-rims come in black
-has NPP
I eaked through 2 winters with them on both of my other cars including my AWD S4 and it was hairy at times. Brand new they were not bad, but after about 1/2 the tread was worn my S4 sits in the garage while we drive our other car with snow tires.
Supposedly the new AS3+ addresses the snow issue.
If your going to truly DD it in the winter get snow tires.
Me personally the E-diff is worth it alone. Even on the street how much quicker you can get on the power in a corner is a significant difference.
I bought the A8, and can tell you that it is great. No complaints.
I bought the Z51/Mag shock options as I specifically bought it for the track, and they are well with the money to me. For a street-only car, neither is really necessary.
The rest of the options are purely cosmetic. Spend away.
The e-Diff gives good traction at full throttle out of a turn on the racetrack... its works.
IMHO it does not make the car safer on the street. Nobody should ever drive a C7 on the street at a speed where the e-Diff makes a difference.
Tires are the single most important performance option on any car. Z51 tire are summer only. You'll end up buying a set of A/S anyway.
Currently have an Audi RS7 and I just sold my 2015 911 TurboS. I've had 11 or so Vettes, most recently a '15 Z51 Coupe that I had problems getting comfortable in. Turns out it wasn't the car, it was me. Had to have knee surgery and was diagnosed with rheumatoid arthritis, which is now under control.
The A/S 3s are fine in light snow btw. I wouldn't even think about driving a Vette in anything more than an inch or so and the A/S 3s can absolutely get you home. Anything deeper and a Vette would be an expensive plow.
Greatly appreciated.[/QUOTE
Daily drive - don't need it. The magnetic ride
