C7 front splash guards
Old Jan 30, 2016 | 12:31 PM
hanks10GS's Avatar
hanks10GS
Default C7 front splash guards
I just received my Z51 Coupe and want to protect the paint from rocks etc right away. About a month ago I was searching for some front splash guards and found a company that made some oversized splash guards that were slightly larger than the tiny OEM splash guards. Of course I thought that they were overpriced for two pieces of plastic but what else is new.
Does anyone know of a good source for larger than factory splash guards?
Old Jan 30, 2016 | 04:05 PM
beekeeper's Avatar
beekeeper
My advice would be to get the factory splash guards painted like your car and then get a protective stone guard film to protect the rest. It's what I did. Looks nice and provides the best protection.
Old Jan 30, 2016 | 06:26 PM
dvilin's Avatar
dvilin
Good advice or you can also add sideskirts. Not cheap and the look is not for everyone's taste.
Old Jan 30, 2016 | 06:40 PM
commander112's Avatar
commander112
Apsis splash guards will solve your problem. Not cheap but they are wider than the tires and will solve the problem. Also, they are fiberglass. My '14 had Xpel film that yellowed slightly in the rocker area on my Arctic White car. I put Apsis splash guards on my z06 and can tell right away that they have pretty much stopped all of the dirt and rocks from hitting the sides. I also added the full aero kit to give the car the z07 looks too.
Old Jan 30, 2016 | 06:42 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
I had the GM guards in my 2014C7 and they did work keeping the car free from stone chips. I sold my C7 and bought a 2015 Z06,I put the GM guards on my Z and did get stone chips on rear quarter. I installed the ACS front guards on my Z and they stopped the chips. The ACS are longer and wider.
GM guards
Acs guards
Old Jan 30, 2016 | 07:04 PM
hanks10GS's Avatar
hanks10GS
I like the side skirt look (Z06 style) and I had planned on installing a pair to prevent stone chips. But I would also like to stop some of the stones before they hit the side skirts. It looks like the ACS splash guards are the size that I am looking for. Just slightly larger than OEM GM.
Thanks,
Hank
Old Jan 30, 2016 | 07:05 PM
hanks10GS's Avatar
hanks10GS
GM guards
Acs guards
Yep, those are the ones that I have been looking for.
Thanks,
Hank
Old Jan 30, 2016 | 08:53 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
On the front they are not very effective considering the C7 shape. Just look at where GM put that heavy plastic, from the center of the door to the back wheel opening. After I added the GM Splash Guards I found the only way to stop stones from marking up that plastic were side skirts. Have had them for over a year and they also let me remove that marked up and discolored GM plastic!
There are many options, I elected to get carbon fiber to match my visible carbon fiber roof.
View of CF Side skirts from Rear
Old Jan 30, 2016 | 09:05 PM
meyerweb's Avatar
meyerweb
What did the APSIS splash guards cost? I can't find any pricing information on their web site.
Thanks.
Old Jan 30, 2016 | 10:39 PM
Randy G.'s Avatar
Randy G.
GM guards on our a Z51 optioned car. Skirts going on as soon as I get them. Until I do the car is parked. 145 miles on it.
Old Jan 31, 2016 | 12:34 AM
commander112
Thanks.
I honestly don't recall. I will try and find the receipt and post back.
Old Jan 31, 2016 | 05:55 AM
JerryU's Avatar
JerryU
FWIW the heavy GM plastic protected my rocker panels until I installed side skirts. The plastic was marked and looked bad and ultimately discolored so I removed it over a year ago. My straight side skirts have provided full protection for over a year with no plastic wrap.
Old Jan 31, 2016 | 08:50 AM
commander112
Found the receipt. Paid just over $300 for the fronts and the same for the rears.
Old Feb 3, 2016 | 06:39 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
I just installed the ACS splash guards. I like the extra protection you get on the side and length, plus they still blend well.
Old Feb 4, 2016 | 07:31 PM
BladeSilver2015's Avatar
BladeSilver2015
Originally Posted by gpzturbo
Hello, This is my first post so please excuse me if I mess it up. I also wanted some larger splash guards other than the factory ones as they just do not provide enough protection and do not extend down past the wheel well. So I made these and they provide the protection I was looking for. I have a few sets of these and some rear sets for sale. These are made of 1/4 inch thick masticated black rubber and cut on a lazer water jet machine. I only made a few as I was not sure how well they would be liked. What do you think?
Very nicely made and I am certain they are effective. However, I think they are a little to big and look too much like the mud flaps on my truck.
Old Feb 4, 2016 | 07:57 PM
BJ67's Avatar
BJ67
Chevrolet has an accessory splash shield that sticks out close to a inch compared to the flush original equipment. They are a direct clip/bolt on replacement and reasonably priced front and rear.
Old Feb 4, 2016 | 08:02 PM
BladeSilver2015
They are adjustable, you can move them up or down, or in and out a little bit if you like. Here are some other photos of the whole car.
If they work for you and you are happy with them that is all that counts.
To C7 front splash guards
Old Feb 5, 2016 | 06:14 PM
meyerweb's Avatar
meyerweb
I think GM's factory splash guards work well enough in the rear, but I'd consider something like that on the front. Maybe not sticking down quite as far, though.
I'm sure they're very effective.
Old Feb 7, 2016 | 12:47 AM
LGarcia2000's Avatar
LGarcia2000
I got mine from RPI, in torch red
Front
Rear
Old Feb 8, 2016 | 07:36 PM
gpzturbo's Avatar
gpzturbo
7th Gear
Default splash guards
Those torch red ones from RPI are GM ones painted to match. They do not stick out far enough to cover the tire width nor do they go below the body to provide enough protection for me, that is why I made my own.
