Dipstick
Old Feb 1, 2016 | 11:07 AM
joemessman's Avatar
joemessman
Default Dipstick
Is it just me, or do some of you have a difficult time reading the oil level on your dipstick? Mine is wet sump model.
Old Feb 1, 2016 | 11:10 AM
Glen e's Avatar
Glen e
the wet sump stick will sometimes read less on one side than the other due to the angle at which the stick hits the oil. Take the high side reading, or turn it 360 in the tube before you read.
Old Feb 1, 2016 | 02:10 PM
meyerweb's Avatar
meyerweb
I've just averaged the two sides. As long as neither side is above or below the cross-hatched section, I think you're fine.
But if that's not what you mean, having a bright light helps a lot.
Old Feb 1, 2016 | 04:48 PM
Maxie2U's Avatar
Maxie2U
Getting an accurate oil reading is the only thing I truly dislike about this car.
I follow the instructions as called out in the manual but I get so many different readings it's frustrating. After the car temp has warmed I wait 5 -10 minutes and sometimes it has ZERO oil on the dipstick. I then drive it let the car seat again for 5 - 10 minutes and the oil reads between the first harsh marks. I then drive it 50 miles and check the oil...sometimes there is no oil on the dipstick other times it shows oil between the first harsh marks.
I NEVER had so much trouble getting consistent oil readings...Very frustrating
BTW, mine is not a Z-51.
Old Feb 1, 2016 | 04:53 PM
DickieDoo's Avatar
DickieDoo
I haven't checked all the C7 DIC Messages, but my old Impala SS had a message that came up, "oil level low... add oil..." Of course those 5.3L motors were oil burners but it would be nice if the car just told you when to add 1 Litre/quart, and you would know that's exactly how much you had to add.
Before i go home an crack open the manual, someone can confirm this...
Old Feb 1, 2016 | 04:59 PM
joemessman's Avatar
joemessman
I took Glen e's advice and gave it the 360 turn. But when cold. I get those different readings when it is hot. I would like to see inside the motor to see where the end of that stick settles in at.
Old Feb 1, 2016 | 05:13 PM
bbcb's Avatar
bbcb
you aint alone ...i thought it was just me ...who the hell designed this thing .... a royal pain in the dipstick !!!
a guessing game to check oil ....
Old Feb 1, 2016 | 07:16 PM
Boozman's Avatar
Boozman
I was looking at that today what a pain in the zss
Old Feb 1, 2016 | 07:24 PM
Larry/car's Avatar
Larry/car
Don't stress over oil level readings. The acceptable range is quite wide. The dipstick just protrudes into the oil pan, nothing mysterious or exotic.
Old Feb 1, 2016 | 09:14 PM
2016SGZ51's Avatar
2016SGZ51
I agree it's hard to read, especially with really clean oil.
Maybe painting the end of the dipstick white would help.
To Dipstick
