They're pretty worthless in my opinion, the worst seat heaters in any car I have had. I also have a Honda Civic. In just a matter of minutes, the seat heaters in that car can have your *** on fire.
The seat ventilators are awesome though, much better than my previously owned BMW and Acura.
Mine work quite well, on hi I feel heat in less then 5 min.
5 minutes may be fine in FL but it takes 10 in SC when it's 35 to 40 before I go to 2 then 1 bar! As you live further North can see where it would take longer!
The thick open mesh under the leather that makes the cooling good - slows down the heat transfer time! If you like roses you have to live with some thorns!
I would consider mine to be in the "worthless" category as well. No comparison to the '05 or either of our Caddys. I've seen all the excuses/explanations relating to the design that have been posted more than a year ago but that still doesn't make it right. In the same category as the non-functioning 'magic wire' that was supposed to aid closing of the hatch. That worked so well GM brought back the pull-down for '16.
