Toggle Switch
Old Feb 12, 2016 | 05:00 PM
redGS12's Avatar
redGS12
Default Toggle Switch
OK, here goes a really dump question. On my 2015 Z51 there is a toggle switch located on the right side of the deck release. It appears to have a lighting logo pic. What does this control??????
Old Feb 12, 2016 | 05:09 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
That will disable the motion sensor in the car. That way if you leave a pet or person in the car, they won't set off the alarm. It resets after you start the car again.
Old Feb 12, 2016 | 05:22 PM
redGS12's Avatar
redGS12
Thank you very much. I thought I had looked at everything the manual had to offer and could not find an answer.
Old Feb 12, 2016 | 07:29 PM
Zymurgy's Avatar
Zymurgy
Moderator
See page 2-18 of the 2015 Owners Manual:
Intrusion and Inclination
Sensors Disable Switch
It is recommended that the intrusion
and inclination sensors be
deactivated if pets are left in the
vehicle or the vehicle is being
transported.
With the vehicle turned off, press off
to the right of the hatch/trunk
release button. The indicator light
will come on momentarily, indicating
that these sensors have been
disabled for the next alarm system
arming cycle.
Old Feb 13, 2016 | 11:06 AM
felkebg's Avatar
felkebg
Think of all of the other nuggets and tech wonders that are still hidden in that book waiting to be discovered..... I think I saw that someone has a thread going or was it a car mag article on undocumented finds for you to consider. Be aware that small variances exist between each model year.
Old Feb 13, 2016 | 11:20 AM
joemessman's Avatar
joemessman
You can say that again. I find little easter eggs quite often even though I read the manual.\ For example: Tap the turn signal up or down (rather than totally engaging it) to get 3 blinks to got left or right.
Old Feb 13, 2016 | 01:44 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Stupid thing about the motion sensor, it is deactivated when the top is off, pretty much the time when you need it most.
Old Feb 13, 2016 | 10:49 PM
meyerweb's Avatar
meyerweb
That's easy to work around. Stick a plastic wall anchor in the hole the top mounts to, on the driver's side.
https://www.corvetteforum.com/forums...post1590309215
Old Feb 14, 2016 | 02:40 AM
themonk's Avatar
themonk
yeah, thanks, I know but WTF would GM design it like that in the first place I have no idea, it just doesn't make sense.
Top on, windows up, doors closed, motion sensor active....
Top off, windows up, doors closed, motion sensor deactivated....
which one of those two doesn't make sense?
Old Feb 14, 2016 | 07:52 AM
Nice Ride's Avatar
Nice Ride
How many times are you going to lock your dog or the kids in the car and turn on the alarm? Just something else unnecessary to drain battery.
Old Feb 14, 2016 | 11:43 AM
joemessman's Avatar
joemessman
They both make sense to me. Why would the sensor be activated with the top off? Maybe I'm missing something here.
Old Feb 14, 2016 | 12:10 PM
Crossed Flags Fan's Avatar
Crossed Flags Fan
To let you know when a "bird of happiness" has made a deposit on the driver's seat?!?!?!
Old Feb 14, 2016 | 12:23 PM
Glen e's Avatar
Glen e
Their thinking is they don't want a leaf setting it off, use the moly holder discussed above, works fine....
Old Feb 14, 2016 | 12:38 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Don't forget, the car auto locks. I had my son in the car and got out to pick up a pizza with him still in the car. I forgot to mash the button, but that's one instance. I can think of lots of situations where it's a nice feature to have.
Old Feb 14, 2016 | 01:09 PM
joemessman's Avatar
joemessman
Certain models must not have this disable switch. Mine doesn't even though the manual states:
release button.
Old Feb 14, 2016 | 01:25 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
It's available on 2 & 3lt trims.
Old Feb 14, 2016 | 08:29 PM
meyerweb's Avatar
meyerweb
release button.
1LT models don't have the motion sensor, so no need to switch it off.
To Toggle Switch
Old Feb 14, 2016 | 10:24 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Best answer yet !
Old Feb 15, 2016 | 03:07 PM
Dif's Avatar
Dif
This is the Motion Sensor shut off button on my 2016 2LT...
Old Feb 15, 2016 | 03:38 PM
owc6's Avatar
owc6
Like this?
Unfortunately, there is no wall anchor trick for a Vert.
