Rearview camera settings
Old Feb 19, 2016 | 10:45 PM
joeytss's Avatar
joeytss
Default Rearview camera settings
I know this has been discussed previously, I have a 2016 Z51, I want to remove the moving grid lines or make them fixed lines, I have gone into vehicle settings but their is no dropdown for rearview camera. Any suggestions? Thank you in advance.
Old Feb 20, 2016 | 01:28 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Page 206 of the manual has this:
Turning the Features On or Off
To turn off the guidance lines:
1. On the infotainment system, press the Settings screen button, or turn the MENU **** to highlight Settings and
press MENU.
2. Select Rear Camera.
3. Select Guidance Lines and then select Off or On.
Old Feb 20, 2016 | 01:37 AM
Joy c7's Avatar
Joy c7
Thanks for Infro did not know this.
Old Feb 20, 2016 | 07:07 AM
joeytss's Avatar
joeytss
Thank you Rooster OG, tried doing that while reading the manual but rearview camera is not a choosable option, could they have taken this option away mid year?
Old Feb 20, 2016 | 08:00 AM
L8ter's Avatar
L8ter
Those guidelines sure do make it a lot easier to get the car even when backing into a parking spot.
Old Feb 20, 2016 | 10:38 AM
Zymurgy's Avatar
Zymurgy
Moderator
Some options are only available if the engine is running. Don't know if this is one of those options or not.
Old Feb 20, 2016 | 12:47 PM
joeytss's Avatar
joeytss
I'm at a lose, I've tried it with engine off and on, I just dont have a rear camera option in the vehicle settings. Does anybody else have it or not have it? Yes it may be helpful while parking, but for me the moving lines are difficult while backing into my garage. I think I prefer fixed lines or no lines like my other vehicles.
Old Feb 20, 2016 | 01:04 PM
Zymurgy's Avatar
Zymurgy
Moderator
I have it on my 2014 3LT:
Settings > Rear Camera > Guidance Lines > On or Off
Note that it is on the top level Settings menu (scroll down). It is not under the Vehicle category.
Old Feb 20, 2016 | 01:29 PM
rothchilds's Avatar
rothchilds
It's on my 2015 as well
Old Feb 20, 2016 | 02:06 PM
joeytss's Avatar
joeytss
I'm sorry Zymurgy, What is the top level settings menu?
Old Feb 20, 2016 | 03:11 PM
Zymurgy's Avatar
Zymurgy
Moderator
Press the Home hard button on the center console, then press the Settings icon (gear). you are at the top level. Scroll down until you see the Rear Camera item. Select (press) it. Hopefully you have it there as well and this is not something that was eliminated in 2016.
Old Feb 20, 2016 | 03:18 PM
joeytss's Avatar
joeytss
Thats exactly what I've been doing, looks like they must have eliminated it for 2016. Thanks again, maybe someone with a 2016 can check for me.
Old Feb 20, 2016 | 03:57 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
It's not on my 2016 either. Lol. I never looked because I like having the lines. I'm wondering if different builds of 2016's have it like the performance & lap timer that are missing on early builds.
Old Feb 20, 2016 | 06:38 PM
fastgts's Avatar
fastgts
2016 Z06 - No Rear Camera option under settings
Old Feb 21, 2016 | 12:03 AM
joemessman's Avatar
joemessman
2016 LT1 base. I have the setting to turn the grids on or off. build date of Oct 2015
Old Feb 21, 2016 | 02:38 PM
joeytss's Avatar
joeytss
Thanks everybody, I guess I will just have to deal with the moving lines. Thanks again
Old Feb 21, 2016 | 03:41 PM
joemessman's Avatar
joemessman
Mention it to the service manager the next time you go in. But try this first. This has helped with three issues I have had. And quite frankly, those are the only issues I have had. Open both doors to the car. Leave the car so the key fob is out of range. Wait about 15 minutes. Go back to the car and close both doors before you get in. You may here the horn and the lights may flash. Now start the car and try to to look at settings again. I know this sounds crazy but I had a GM representative share this with me when I had my first minor issue with the car. It fixed it. And subsequently fixed two more issues I had.
To Rearview camera settings
Old Feb 21, 2016 | 06:04 PM
joeytss's Avatar
joeytss
I will be sure to try that tomorrow morning, thank you for the tip.
Old Feb 22, 2016 | 03:14 PM
joeytss's Avatar
joeytss
Joemessman...Tried it, but it was a no go....Thank you for the tip, it was worth a shot.
Old Feb 22, 2016 | 07:07 PM
defaria's Avatar
defaria
I don't have a Rear Camera under Settings (2016 Z51). That's OK because I prefer them on anyway.
