Z06 rear vent installation catastrophe
Old 02-20-2016, 04:43 PM
Wilross3
Support Corvetteforum!
Wilross3's Avatar
Default Z06 rear vent installation catastrophe
Ok, may be in the big picture of all things not a catastrophe. But caused me to express a few "army words" as my Dad used to put it.
The following 2 users liked this post by Wilross3:
geo2000 (02-20-2016), OLD_GOAT (02-20-2016)
Old 02-20-2016, 05:20 PM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
Well that sucks.
I wonder if it was adhesive that got pushed out from installing the quarter windows at the factory. I noticed with mine it seemed like the rubber weatherstripping had 'melted' a little bit onto the quarter panel. I used a heat gun to get it all nice and soft, made the install a lot easier.
They'll get it fixed!
Old 02-20-2016, 05:39 PM
Larry/car
Larry/car's Avatar
Sorry about your cracked panel. That is why I don't do mods to a new car.
Old 02-20-2016, 06:00 PM
Woodson
Woodson's Avatar
Received 1,365 Likes on 790 Posts
Sorry that happened to you. And no, it doesn't look better.
Old 02-20-2016, 06:10 PM
geo2000
geo2000's Avatar
Sorry about the crack but thanks for the heads up, getting ready to do mine in a few days.
Old 02-20-2016, 06:18 PM
SRQStingray
SRQStingray's Avatar
Man, that sucks. This is the type of thing I dread on any DIY project.
Old 02-20-2016, 06:21 PM
Scoobydoobydoo
Scoobydoobydoo's Avatar
The vents look great but boy stories like this scare the heck out of me. Got mine in the box waiting for the install.
Old 02-20-2016, 07:34 PM
BladeSilver2015
BladeSilver2015's Avatar
I am liking my stock vents more every day.
Old 02-20-2016, 08:27 PM
RipcordZ51
RipcordZ51's Avatar
I nearly got brave today - 60 degrees in MA in Feb!!! But no, I think I'll have these done at a shop. And yes, they definitely look much better than stock!
Old 02-20-2016, 08:42 PM
Red C8 of Jax
Red C8 of Jax's Avatar
Received 1,113 Likes on 753 Posts
Bill, looks like one of my projects, "What can go wrong will go wrong".
Old 02-20-2016, 08:59 PM
Hammerman
Hammerman's Avatar
I have been thinking of this mod for my car and may just keep thinking about it. I am sorry to see what happened to your car.
Old 02-20-2016, 09:07 PM
555ctsv
555ctsv's Avatar
Man that sucks! I had the whole rear end off my car when i did mine (was doing other stuff at the same time) and i think that made it a little easier. I did drop a screw/nut but thankfully i just stuck a telescoping magnet down in the panel and retrieved it with no issues. The crack and tool residing in the body would drive me nuts!!
Old 02-20-2016, 09:20 PM
Wilross3
Wilross3's Avatar
Thanks friend, was hoping someone would throw a little more negativity my way...
Magister Ludi (02-21-2016)
Old 02-20-2016, 09:43 PM
555ctsv
555ctsv's Avatar
I think they look great! Its a subtle but nice upgrade. I was debating on it but am glad i did it
(Throwing some positivity your way!)
Wilross3 (02-20-2016)
Old 02-20-2016, 10:00 PM
nmvettec7
nmvettec7's Avatar
The black adhesive is definitely from the installation of the small rear quarter window. When I installed my Z06 vents 5 months ago, I noticed the exact same adhesive.
Do not use a pry tool, but instead, use a thin blade SHARP knife to SLOWLY cut the adhesive that has oozed out from the window onto the underside/edge of the rear quarter panel composite.
You will simply insert the knife blade between the rubber trim and the composite rear quarter panel. Cut slowly. Using a pry tool will only place extreme pressure on the composite material.
The black adhesive may only be 1 inch in length to cut or may be more.
Another PITA when installing the Z06 vents is the last 1 to 1 1/2" of the rubber trim in the very rear of the small quarter panel window. I can be very difficult to replace and push the composite panel back underneath the rubber trim molding.
Best to you all.
Old 02-20-2016, 10:59 PM
freddieg
freddieg's Avatar
Drivers side vent replacement went without a hitch. The usual warnings about screws falling into the abyss helped me prepare for that. No problem.
Passenger side seemed to be going smoothly. Screws out, but panel wouldn't budge. Used a plastic trim tool to carefully pry the panel back. Got it out about a quarter inch and it just seemed like there was another fastener somewhere I was missing. Searched to no avail. One more pull, and cracked the body panel. After looking closely at the panel there seems to be some very strong, very hard adhesive that was actually attaching the panel to the underside of the window. You can see the black adhesive in the photos.
Only a small crack but it will drive me nuts. Guess when it's at the shop I'll have them fix any small rock chips before it goes to the Xpel installer.
Oh, and the plastic trim tool disappeared into the abyss. Hope it doesn't cause a noticeable rattle. Argh...
Hope this helps someone out doing this install.
They do look better than the stock vents.
Good luck!
Bill
BTW - '15 Z51 3LT built September '15.
Driver's side. Looks better than stock for sure!
Bill, if your car was built in Sept. of 15 you have a 2016!
Old 02-20-2016, 11:04 PM
Woodson
Woodson's Avatar
No offence was intended. I was just disputing your "fact"
To Z06 rear vent installation catastrophe
Old 02-20-2016, 11:22 PM
Wilross3
Wilross3's Avatar
Thanks... Build date corrected.
B
Old 02-20-2016, 11:39 PM
BlueDevilZ51
BlueDevilZ51's Avatar
Sure they can fix that tiny crack easy...Vents look great.
Old 02-20-2016, 11:45 PM
BenCasey
BenCasey's Avatar
Thank God! We finally have forum fact police!
Yeah, OP, take that and your stupid problem!
Here's a fact: I have excellent taste. Another fact: z06 vents look better than stingray ones.
Woodson, I'll need you in a few threads if you have the time, too many bad facts in them.
The following 3 users liked this post by BenCasey:
Joy c7 (02-20-2016), markmott (02-21-2016), Wilross3 (02-21-2016)
Quick Reply: Z06 rear vent installation catastrophe
