My car sits outside and leaves fall into the fender vents. Will they build up and eventually block the trans/differential cooling ducts? Is there a way to clean them out?
I assume you are talking about leaves that get past the cross mesh in the intakes. Not a problem. The ducting tops short of the coolers, so they will just drop to the ground when they go down the ducts.
I'm not sure they are functional regardless. Might depend on what C7 you have. From what I have read on the base C7, the manual has no working vents back there, the auto has one side open, and the 51 has both sides open. You might want to check and I could be wrong but.......
