New 2016 base car with auto trans. I have tried out the launch control a couple of times and am not sure of the results. I've followed the instructions exactly i.e. in Track, middle button pressed twice for the two lights on the dash, stand on the brake, accelerator to the floor. The engine goes quickly to about 2000 RPM and then drops to about 1500. I let off the brake and the car seems to bog just for a second but picks up immediately and takes off. No tire spinning and except for the slight bog when the brake comes off, solid acceleration. I'm not getting 4 seconds to 60 MPH, more like 5.8 seconds but then again, it has all season tires on if that would make a difference. Does this sound correct to you more experienced folks?
On our last day of school at spring mountain this Thursday the instructors demonstrated launch control on a stick shift and automatic. The steering wheel must be pointed straight ahead, hard on the brake and the throttle to the floor in the track mode with the button pressed twice like you did. The automatic car rpm went to 2000, brake was released and the car took off with very little wheel spin. In the stick shift car the rpm went to 5000, hard on the brake and dropped the clutch. It had more wheel spin, the automatic was faster off the line. I suspect you did everything correct because if you did not you would have had lots of wheel spin. Not hard to spin the tires with an automatic. Next time just put the brake on, engine to 2000 rpm and see how fast you melt the tires without the launch control.
As I recall, I did it two ways. I did everything you described. If, while the brake was on I let off it at 2000, it burned rubber and then took off. If I let it go to 2000 and then stayed on the brake, it would drop to 1500, I'd let off the brake and it would bog just a little and take off without any wheel spin whatsoever.
If the tires are cold it won't launch as hard. I'd suggest doing a little burn out/ power brake to heat the tires. After that it should have better traction and launch harder.
Here are a couple of youtube vids of me practicing my launch. Car is bone stock 2015 Z51 with the stock tires at 35 pounds. I was practicing my launch on a spring day on the side of the road. No track prep or anything, just a deserted road.
I did exactly like the book stated....panic brake, let the revs build up, then release the brake. Track mode, hit the traction control button twice to the the car in competitive mode. In the first video, you can hear me something like I can't brake enough or something like that. You can also see the car ease up and groan. I finally got a good launch for a 3.8 zero to 60 mph.
Easing up isn't good cause at the strip when you ease up and set off the timer, you've blown the run. So you have to really brake hard and ease on the throttle.
The second video was taken around 15 minutes later as I tried it all over again. This time the car reacted better to my panic braking and I got off a really great 3.6 zero to 60, which I'll take any day. I was still easing up, but not as bad as in the first video.
Great vids. I noticed your car can go to higher RPM before you release the brake. I've had no problem standing on the brake hard enough but like I said, once I floor the pedal it will go to 2000 RPM and then back off to 1500 RPM before I release the brake. it will bog slightly letting off at 1500 and burn rubber if I let off at 2000. Those all season tires probably don't help (I wanted to drive through the winter) and I didn't have more than 29-30 lbs. of air in them. If there was a place in town that I had enough faith in to do a decent job of putting on the summer tires and balancing them, I might be tempted to do it and put the others back on next fall.
I've tried it and beat it every time. My best results were actually, unlike my C6, from idle. Less burn and less fishtailing. Guess I'm just too old school.
What mode are you in when you take off? I was tempted to just leave it in tour, mash the brake, floor the pedal and release after the RPMs come up.
Was there a general idea that using the launch control after adding a blower and such was a bad idea? I added cam, blower, meth to mine right after i got it and never used the launch control when it was stock. I thought i read somewhere that using it with a modded car was bad for the trans?
I have a question in regards to Launch Control & Automatic Transmission.
The owner manual says to follow these instructions to initiate Launch Control.
Automatic Transmissions
* Set mode to Competitive Driving Mode (Track)
* The brake pedal must be firmly pressed to the floor, equivalent to a panic brake event.
* The accelerator pedal is rapidly applied to wide open throttle. (If the vehicle rolls due to wide open throttle, release the throttle, press the brake pedal more firmly, and re-apply the accelerator to wide open throttle.)
* The Launch Control feature will initially limit engine speed as the driver rapidly applies the accelerator pedal to wide open throttle. Allow the engine rpm to stabilize.
* A smooth, quick release of the brake pedal, while maintaining the fully pressed accelerator pedal, will manage wheel slip.
I assume prior to fully depressing the accelerator the transmission (shifter) must be in Automatic "D" and cannot be in "M" (manual/paddle shift) mode?
When doing the above, what RPM is your engine stabilizing at before you release the brake?
Not trying to hijack this thread, but, I, and I suspect quite a few others, am having the same exact outcome as the original poster. I have the 2016 Z51 auto also. Following the procedures as outlined above, mine goes to 2000rpm, then stabilizes at 1500 rpm. Brakes released, get the slight bog, sometimes a little wheelspin. The times haven't been better than about 5 seconds. The car has only 700 miles on it and has been put away until I get back in May. What are we doing wrong, so that it can be corrected when I get back to it in a few weeks? Sure would like to match those You Tube times! Good work!
Thanks for any input.
You did a good job of hijacking the thread and asked just the right question. I just took a little ride and tried a few 0-60 runs and found out where part of my time goes. The 0-60 timer, at least on mine, starts running when I floor the gas pedal-not when I release the brake. I can't hold down the brake any harder than I am. Maybe it slips just enough to start the timer-I don't know. I can't feel it move. What are other folks experiences?
Yes, keep the car in D. In M, you can't out shift the computer.
Use the PDR if you have one, however it may not be right on the money.
Highplains: What mode are you in when you take off? I was tempted to just leave it in tour, mash the brake, floor the pedal and release after the RPMs come up.
This is what I've found works best for me. I don't know if other people found this to be so but what works works. I run in TRACK mode, hit the traction control twice which puts me into "Competitive Mode". Then when I stage at the second yellow I hold hard on the brakes & quickly floor the gas and then let off. This "flashes" the transmission. In other words sets the torque converter to accept high RPM. Then I let the car return to idle. At about midway thru the third yellow ( I usually mentally count to 3 secs.) stomp on the gas. By the time I'm moving the light's on green. My C6 was totally different as is every car. So good luck.
PS:make sure your AC is off. It's a power robber. Also stay in D. I do a 3-4 second tire heat up but that's all folks.
This is what I do. And I get 3.7 give or take a tenth every time. Tires warm and good pavement.
Drive Mode Selector To Track mode
Press Drive Mode Button Twice with 2 seconds between presses.
Steering Wheel Straight
Car in Drive
Floor Brake
Floor Gas - It will rev high and then settle in.
Release brake quickly.
Car in Drive
Floor Brake
Stick or auto? I do all the same with my A8 and the revs go to 2000 and then drop to 1500. As mentioned previously, my 0-60 MPH timer starts when I hit the gas pedal which is giving me bad readings. I did, however, find reports from others about that. When this has occurred to them, they keep the brake on, foot on the gas, reset the timer which then starts at brake release.
You've got to stand on the brake and then mash the throttle hard to the floor all at once. You are not pressing the throttle down quickly you are just feathering it to 2000 then flooring it. That being said, a 3.6 0-60 on the marbles of the shoulder is really exceptional, your car runs really well.
