Jacking pucks
Old Mar 11, 2016 | 08:30 AM
Gabrielk's Avatar
Gabrielk
Default Jacking pucks
First time I heard about the jacking pucks was in this forum a week or so ago, didn't even know they existed.
Question is, is this really necessary ? Every other car I've had and needed to jack it up I just do it in the area where I'm suppose to, why any different with a corvette ?
Old Mar 11, 2016 | 08:39 AM
roSSco's Avatar
roSSco
The jacking location is next to the body panels. The pucks keep the jack from damaging them.
Old Mar 11, 2016 | 08:42 AM
Kracka's Avatar
Kracka
Hockey pucks work perfectly. You will need some type of puck or pad to lift the car with a jack.
Old Mar 11, 2016 | 09:04 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
The answer, IMO is they are needed!
Just left this message on another tread where the person had a cracked rocker panel! Not easy to replace, best just to repair. This is what I posted:
Got my C7 in October 2013. GM requested I bring it back to have the differential fluid level checked. I had jack pads as I did for my C6 and when I brought the car in for service asked the gal who schedules maintenance to be sure they use my 4 jack pads that I left on the passenger seat.
Knew her from my C6 and was always impressed with her knowledge. She said, "Don't worry I will be sure they use our drive on alignment rack and not our center post lifts," (of which they have ~12 versus one drive on alignment rack.) She continued and said, "We just cracked a Vette rocker panel and had to repair it!"
She also brought me into the repair bay, introduced me to the recently C7 trained Vette mechanic who let me watch as he checked the fluid level (it was fine.)
I have NOT had to bring my C7 back to the dealer since, I do my own oil changes etc. If I do bring it to the car dealer or a tire shop, I will emphasize the need to use my four, 2 inch high jack pads (needed to clear my carbon fiber side skirts.)
In fact wish I had purchased the Reverse Logic jack pads that can be temporarily bolted in place so I don't have to "hope" the mechanic will follow my request to install mine! FWIW
One other note re the size. Hockey pucks and the aluminum ones I had for my C6 were 3 inches in diameter. GM says for the C7 to make them max 2 1/2 inches. I found the rocker panels on a C7 are closer to the shipping slots where they fit! If you make them from hockey pucks AND use eye hooks you probably can shift them over so they won't hit the rocker panels. Have to hope the dealer service folks do the same! However if buying them they are available with the proper diameter, like those from Reverse Logic.
This is a PDF of my install with lots of pics, if interested: http://netwelding.com/Jacking_pads.pdf
Gabrielk's Avatar
Gabrielk
Makes sense, just bought a set.
Thanks guys
Old Mar 11, 2016 | 09:09 AM
Gabrielk's Avatar
Gabrielk
Oh wow, yea glad I asked before just going ahead and lifting it up with no pucks !
Old Mar 11, 2016 | 12:40 PM
PNorris's Avatar
PNorris
Use a hole saw and cut out a section of a 2x4. That is what I did. I just put it on top my jack and it is that easy.
Old Mar 11, 2016 | 12:50 PM
JerryU's Avatar
JerryU
That works for home use IF when you're using a hydraulic jack you are carful to have it perpendicular to the car and watch that it moves in as you raise the car. Pucks installed in the shipping slot help the Jack saddle not slip. Screwing a large eye hook in the center of the wood circle would help.
Perhaps more important to me is having pucks for a dealer or tire shop to use. Many either don't have them or don't take the time to use them. Cracked rocker panels can't easily be replaced; a bondo type repair is probably best but not desired!
Old Mar 11, 2016 | 12:57 PM
only9balls's Avatar
only9balls
I got the plastic ones that snap in place and stay on the car, they work great.
Old Mar 11, 2016 | 01:21 PM
JerryU's Avatar
JerryU
They work great and no need to worry about the dealer using them! However with my vertically contoured Carbon Fiber Side Skirts I need the 2 inch high ones to be sure if a center lift is used the lift pads don't hit my skirts. They also help clear my jacks.
Old Mar 11, 2016 | 01:28 PM
millpond's Avatar
millpond
I agree, these work great:
Old Mar 11, 2016 | 01:44 PM
Gabrielk's Avatar
Gabrielk
Well my hesitant self bought the rubber ones without thinking ahead of myself, now whenever I decide to add the side skirts I'll have to buy the 2in set, oh well at least I'll be safe for now
Old Mar 11, 2016 | 01:55 PM
only9balls's Avatar
only9balls
Yep, those are the ones. I have sideskirts, and haven't had any issues so far, although, I haven't taken it to the dealer for anything (nor do I plan to).
Old Mar 11, 2016 | 04:03 PM
BladeSilver2015's Avatar
BladeSilver2015
Old Mar 12, 2016 | 09:14 AM
myc6toy's Avatar
myc6toy
Will the C6 pucks work on a C7 ?
Old Mar 12, 2016 | 09:38 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Yes they do
Old Mar 26, 2016 | 04:50 PM
427Z0SX's Avatar
427Z0SX
Not necessarily!
C6Z has aluminum frame, as do ALL C7s. These use the same kind of pucks.
"Regular" C6 has steel frame, so there are 2 kinds of pucks for C6 Corvettes; Z06 puck and non-Z06 pucks.
To Jacking pucks
Old Mar 26, 2016 | 05:11 PM
owc6's Avatar
owc6
My Z06 pucks fit. My '05 pucks don't . The aluminum frame is thicker, so the neck needs to be longer .
Old Mar 26, 2016 | 05:12 PM
carpe dm's Avatar
carpe dm
I use hockey pucks; they work great.
Old Mar 26, 2016 | 05:42 PM
PLRX's Avatar
PLRX
2017 C4 of Year
The pucks I'm using on my 16 Z06 came off my C5 Z06. I wonder the reason yours dont fit.
