Rear camera problem
Old Mar 17, 2016 | 02:16 PM
ElSpa's Avatar
ElSpa
Default Rear camera problem
I searched for the problem, it seems that mine is doing something different.
When the car shakes alittle the image on the screen flickers and I get Service Rear Vision. I disconected and reconected the plug, same thing. My display is fine (seems other people had problem with the display itself).
I don't have an american GM dealer in my country, so it's up to me to fix it...would a new camera solve the problem ?
Old Mar 17, 2016 | 06:25 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Where does that wire go? Does it go up to the module in the drivers kick door? Maybe check that connection too?
The camera I found on CULTRAG which may or may not be right, is $120, kinda expensive for just a maybe fix. Here's the listing I found:
http://www.cultragfactoryparts.com/oe-gm/23199271
Old Mar 17, 2016 | 07:48 PM
agapsdiver's Avatar
agapsdiver
What plug did you disconnect and reconnect ?
The one under the rear bumper Fascia in the center coming off
the camera and plugging in to the wiring harness???
Old Mar 18, 2016 | 12:14 AM
ElSpa's Avatar
ElSpa
I did disconect the one on the boot floor, around the ECU area...is there one under the rear bumper too ?
Old Mar 18, 2016 | 08:36 AM
agapsdiver's Avatar
agapsdiver
Yes, I had the same problem with flickering rear view camera and
random "Service Rear Vision" black screen, Took it to dealer several times and they could never get it fixed.
When I installed a Z06/Z07 rear spoiler on my Z51, I had to remove the rear fascia. There are two connectors behind the fascia, one for the tail/turn signal lights and the other for the rear camera. This is the one that I disconnected/reconnected to install the spoiler and since then my rear camera has worked great. I have an early 2014 C7, S/N 1459 and figured they had some initial problems.
Old Nov 15, 2017 | 12:31 PM
lennykoll's Avatar
lennykoll
I have OCCASIONALLY had this happen..... normally rear camera works fine..... did anyone else find a cause/fix that they would like to share!!??....LK
Old Nov 15, 2017 | 02:06 PM
agapsdiver's Avatar
agapsdiver
Originally Posted by lennykoll
I have OCCASIONALLY had this happen..... normally rear camera works fine..... did anyone find a cause/fix that they would like to share!!??....LK
See Above ^^^^^
Old Nov 15, 2017 | 05:46 PM
lennykoll's Avatar
lennykoll
Originally Posted by agapsdiver
See Above ^^^^^
Did!! In fact I sent a copy of the text to my Service Adv. for his take on if they would take a shot at "fixing" it via connector massage.....no word back yet......LK
To Rear camera problem
