Playlist help needed
Old Mar 20, 2016 | 03:07 PM
traderfjp's Avatar
traderfjp
Default Playlist help needed
Hi,
I don't use itunes but have a few hundred songs I want to put on my USB drive. Can anyone tell me how to make playlists so my car doesn't play the same song over and over again. I did a search and it always comes back to itunes. Thanks
Old Mar 20, 2016 | 03:38 PM
w0rM's Avatar
w0rM
There are lots of playlist creators out there. Here's one: http://www.oddgravity.de/app-opc.php
Old Mar 20, 2016 | 07:51 PM
Swt_86's Avatar
Swt_86
Without knowing how comfortable you are with computers, I am going to go out on a limb here.
In Windows, absolutely the simplest and quickest way to create a playlist is to work from a command window. Once you have your songs on the USB device, note the drive letter of the device. You can use windows explorer for this. Now, open a command window. This may be a little different depending on the operating system but Mr. Google can be a great help here. Once you have a command window open, type in the following commands: (without the quotes of course)
"d:" [ Use the drive letter you found with explorer -it could be any letter- in this case it is d]
Next, type in this command:
"dir *.mp3 /b>Playlist.m3u" [You can cut and past that (between the quotes) into the command window if you want]
To verify you have indeed created the playlist, type in "notepad Playlist.m3u" which should open your playlist in the notepad program.
This seriously takes less than five seconds and puts all of your mp3's on the playlist. Of course to name it something other than Playlist, just substitute your name for it in place of "Playlist" in the command line.
Old Mar 20, 2016 | 08:33 PM
mart86vette's Avatar
mart86vette
Default Playlist
I have been making my playlists on a USB drive and I have all my music by artist on another usb drive.
I use the following to make My playlists:
https://www.corvetteforum.com/forums...-creation.html
To Playlist help needed
