Check Engine Light
Old Mar 25, 2016 | 11:27 PM
Volfan55's Avatar
Volfan55
Default Check Engine Light
My 2016 Z-51 with 797 miles check engine light started flashing after about 5 minutes into a trip to the grocery store. The light went off nearly 2 minutes , I parked and went inside for just a few minutes once returing home the light came back on and stayed on . The manual says this is probably an emissions problem. Has this happened to anyone else and if so what was the fix . Thanks in advance !
Old Mar 25, 2016 | 11:33 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
It's under warranty. Take it to a dealer, get the codes read and let them fix it.
Old Mar 25, 2016 | 11:42 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
flashing CEL is not usually an emissions problem, from my experience, flashing CEL means pull over and turn the car off.
In this day and age why people don't have an OBD II scanner stored in their car or garage is totally beyond me.
Old Mar 25, 2016 | 11:49 PM
4thC4at60's Avatar
4thC4at60
Because not everyone can - or wants - to work on their cars: particularly when still under warranty.
Old Mar 25, 2016 | 11:55 PM
Volfan55's Avatar
Volfan55
I'll drive about 5 miles to the dealer in the morning !
Old Mar 26, 2016 | 12:01 AM
themonk's Avatar
themonk
a little information goes a long way. If I'm driving and a CEL comes on and I read it to be Bank 1 H2OS sensor circuit low voltage (aka bad O2 sensor) I know it's not harming my engine at all and I can still drive it forever without doing any damage vs Low Oil Pressure at which point I know to pull over then tell me isn't it worth the 40 bucks I paid for the scanner. People have to learn to be self sufficient, at the very minimum they could be armed with info so if they take it to a mechanic they at least know somewhat what's going on.
Old Mar 26, 2016 | 12:11 AM
Volfan55's Avatar
Volfan55
Oil pressure & engine temperature are fine according to the gauges,I washed it last Saturday and noticed the tail pipes really dirty and no I haven't tracked her or ran her really hard !
Old Mar 26, 2016 | 01:04 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
If your On Star is still active press the blue button and have them give you the fault code and readout
Old Mar 26, 2016 | 01:15 AM
maugust24's Avatar
maugust24
Exactly, push the blue button and they run a scan as you are driving.
Old Mar 26, 2016 | 01:41 AM
MikeLsx's Avatar
MikeLsx
Most people are not going to be able to work on their own car anyways. Even if they know what code it is.
For me its simple. If my check engine light goes on, i take it to the dealership. IF my car breaks down on the way there, GM will send me a tow truck and rental car.
Old Mar 26, 2016 | 07:28 AM
Curahee's Avatar
Curahee
Don't argue with THE MONK.
Old Mar 26, 2016 | 09:04 AM
dvilin's Avatar
dvilin
Old Mar 26, 2016 | 09:27 AM
KWC6's Avatar
KWC6
This happened to me with my 2016. I had 350 miles on it when the light came on. Long story short, take it to the dealer. No big deal. Whatever it was they fixed it in 20 minutes.. All this computer stuff. Never came on again, now with 6500 miles on it, trouble free.
Old Mar 26, 2016 | 02:26 PM
ck9887's Avatar
ck9887
No reason why anyone with a brand new vehicle should feel the need to carry a scanner tool in their vehicle...
Car is under warranty. If more harm is done by driving the car a few miles to the dealership, that's on GM's dime.
Old Mar 26, 2016 | 02:54 PM
Mobil 1's Avatar
Mobil 1
Flashing check eng light is usually indicating a missfire code.
Old Mar 26, 2016 | 08:05 PM
KWC6's Avatar
KWC6
I remember now,it was a misfire code.
Old Mar 26, 2016 | 09:24 PM
owc6's Avatar
owc6
If there is a steady CEL, then it's probably a non emergency, and it's ok to drive. BUT, if it's a flashing CEL, it is something that needs to be addressed, and not driven!
To Check Engine Light
Old Mar 26, 2016 | 11:27 PM
Volfan55's Avatar
Volfan55
Misfire at 237 miles and then again at 802 miles that's when the light came on and stayed on. Had to leave it at thr dealer the misfire occurred during cylinder deactivation
Old Mar 27, 2016 | 12:52 AM
BenCasey's Avatar
BenCasey
Hey, if I may ask... How does one decipher the codes from an OBD scanner?
Old Mar 27, 2016 | 01:04 AM
Kracka's Avatar
Kracka
OBDII codes are standardized, if the scan tool just gives a code and no description, a quick search of the code on Google will tell you what it is.
