Track/Street Alignment
Old Mar 31, 2016 | 08:27 PM
messy1's Avatar
messy1
Default Track/Street Alignment
Hello
I was looking for some specs. on a toned down track alignment. It is mainly a track car but will street drive it also.
Thanks in advance
Old Apr 1, 2016 | 09:49 AM
C6Brain's Avatar
C6Brain
Originally Posted by messy1
Hello
Thanks in advance
I used the track settings in the owners manual.
No real issues driving on the street with these settings.
Old Apr 1, 2016 | 11:16 AM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
Use -.5 Camber on the fronts for the street and your tires will wear even from side to side. OEM performance alignment will use -.8 Camber but over time will wear the inside edge of your tires front tires. Heavy track alignment would be -2.0 and up; you can still drive it on the street but the wheel will not always return to center after a sharp turn and the tires will suffer big time wear on the inside BUT it will corner like its on rails.
Just remember; for action there is an equal and opposite reaction.
Old Apr 1, 2016 | 01:58 PM
blueray16's Avatar
blueray16
admittedly, I've no experience yet with my new C7 but with other cars, I've experienced acceptable street driven wear on the front tires all the way up to -1.5* camber with 1/16" toe in.
Once I went up to -1.7* camber the inside edges started to wear badly. None were daily drivers, just weekend toys.
Old Apr 1, 2016 | 02:08 PM
big red one's Avatar
big red one
How long does it take to change from the standard setup to the track set up as displayed in the manual
To Track/Street Alignment
