What am I doing wrong?
Old Apr 1, 2016 | 10:03 PM
vettman96's Avatar
vettman96
Default What am I doing wrong?
When I reverse and then go forward my mirrors do not return to the set position, (only come back 1/2 way). I have been in settings and verified them, and reset the mirrors to no avail. HELP or do I just need a lobotomy.
Old Apr 1, 2016 | 10:09 PM
thenorthwoods's Avatar
thenorthwoods
My 2016 Z did the same thing, I ended up not liking it and shut that function off in the settings.
Old Apr 2, 2016 | 12:14 AM
MBNWA's Avatar
MBNWA
Mine started to do this the last few days (got it on 2/29/16) it seems to be hit and miss sometimes it only returns 1/2 way other times it goes back to the set position when it goes half way I can press and hold the memory preset and it does reset - I have only seen this with my passenger mirror not the driver mirror
Old Apr 2, 2016 | 03:15 AM
mpuzach's Avatar
mpuzach
It's good to see you here, Mike!
Old Apr 2, 2016 | 09:24 AM
08G8V8's Avatar
08G8V8
I have mine set to go down when in reverse, and when backing into my garage they will go down, but then partway down the driveway(while still in reverse) they will go back up. No clue why, other than taking the foot off the gas, but as long as it's in reverse they should stay down. I drive a manual by the way. Anybody else have this issue?
Old Apr 2, 2016 | 09:55 AM
vettman96's Avatar
vettman96
Well, at least I know I'm not alone, and a lobotomy is not required. Thanks for the responses.
Old Apr 2, 2016 | 09:18 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
They only stay down for about 30 seconds, I think, then return to settings. That is why I disabled mine. I set mine down and adjusted and saved under #2 setting. That way when I need it, I press the #2 memory, and reset to #1 when I am through.
Old Apr 11, 2016 | 04:29 PM
Fcal's Avatar
Fcal
Same here.
Old Apr 11, 2016 | 04:44 PM
traronf's Avatar
traronf
My Cadillac does the sane thing. Turned it off on both cars.
Old Apr 11, 2016 | 05:09 PM
T-Z06-J's Avatar
T-Z06-J
Your seat or steering wheel is at the limit. Move your seat and/or your steering wheel one click from that limit and save that in your seat memory.
Its weird, sounds unrelated, and maybe even a little retarded, but the mirror will not return to the stored position when your seat/steering wheel is at the limit switch.
Good luck!
Old Apr 11, 2016 | 05:28 PM
vettman96's Avatar
vettman96
Good luck!
I'll give that a shot, thanks a lot.
Old Apr 11, 2016 | 06:51 PM
rcooper's Avatar
rcooper
St. Jude Donor '15
I don't have that problem. My settings are as T-Z06-J mentioned. But my wife has that problem in my new Regal GS that she drives...maybe it'll work on that also. Thanks for the reminder, T-Z06-J.
Old Apr 11, 2016 | 09:51 PM
Dave80C3's Avatar
Dave80C3
That happens to me about 40% of the time when I back into the garage.
Its aggravating when it does it, as I use drivers mirror to see where the back tire has to stop.
Old Apr 11, 2016 | 10:58 PM
wayles's Avatar
wayles
My 2015 Silverado LTZ does the same thing, but my 2014 vette mirrors stay down till I switch out of reverse. Go figure.
Old Apr 12, 2016 | 02:34 AM
only9balls's Avatar
only9balls
This is a great idea! How did I not think of this?
LOL
Old Apr 12, 2016 | 07:14 AM
C7Joy's Avatar
C7Joy
Likewise.
Old Apr 12, 2016 | 08:17 AM
nytrorcr's Avatar
nytrorcr
Default Mirrors for REV.
Mine had done the same, never seem to return to forward drive mode. So I also shut off the function.
Old Apr 12, 2016 | 08:42 AM
BELVIN20's Avatar
BELVIN20
Wow, my Z works perfect, after reading these post, not sure why. In my Z, when I back down my steep driveway, the mirrors continue to tilt down so the I have the same view. Like the function, wonder what I did right in the settings.
Old Apr 12, 2016 | 11:10 AM
only9balls's Avatar
only9balls
I have never had an issue with mine either, although, I have had times where hey time-out and return to the normal position before I am done using them to back up, if I am taking too long. But they never get stuck half-way.
To What am I doing wrong?
