Auto-Dimming rearview mirror upgrade
#42
just talked to my Stealership, informs me i need to buy the whole mirror, housing and whole jam, then have it painted. i can t see that happening. any pics i have viewed shows the glass attaching to the acuator/adjuster and wires run off of it. He tells me the wiring harness is way different. oh well. was worth a try.
thanks for all the input.
Al
Al
walleyejack (10-26-2016)
#43
Yes, the most expensive way is to buy a new housing, paint it, and install. You can re-use your existing housing (change the glass), if you are handy enough to fish 2 new wires thru your old housing, into the door, across the hinge, and up to the interior mirror. Of course the dealer tells you the most expensive way to retrofit this.....
#44
Sorry to dig up an old thread, but I hope someone can help me with this. I have the auto dimming mirrors. Rear window is tinted. I was driving down a dark road last night with no other cars behind me, but for some reason the rear view and side mirrors were both dark. The rear view was so dark, I couldn't see anything. I'm not sure why it is darkened at all when there are no other vehicles behind me, but from what I have read that's just the way GM made it. Has anyone used these lightdims stickers successfully and if so did you put them on the sensor facing the windshield, or the one on the mirror? Did the black or silver look better? I really want to be able to use my mirror at night, and right now, I simply can't.
#45
I like the silver ones on the RV mirror better than the black ones. They are matte, however.
Post #39 has the location.
#46
So, I would place it on the mirror itself to fix the issue as oppose to the front sensor that faces the windshield?
I still don't understand why the dimming feature would even activate when there are no vehicles behind me.
#47
I just experienced the same thing. Both mirrors went black. I recently had the front window tinted with a very light tint. First I drove it in the late evening with the top off. No idea why it would go dark. I would have thought it would go lighter.
Any help would be appreciated. Thanks
#48
I have come to the assumption that the mirrors dim whenever the sensor on the dash decides it is dark enough to go into night dimming mode (dim interior lights & turn on headlights)? At least that is what I have noticed recently as I haven't driven much at night. I have my lights in auto, not sure if that has anything to do with it?
My F250 & Lexus both have auto dimming rearview mirrors & only dim if lights are shinning directly into them. On the Lexus you can also choose the sensitivity of the sensor on the dash as to when it dims the dash & turns on the headlights. Wish the Vette worked like these 2 vehicles that are significantly cheaper.
#49
As close as we dumb-schmucks can figure, it's a combo of the dash sensor thinking it's dark (dim?), and any light from behind "shining" in the sensor on the rear-view mirror.
What "mode" you leave your lights on , apparently, has nothing to do with it.
This is one area, IMO, that the C7 took a step backwards from what the C6 did; there is no way to disable this auto dimming feature, and it works "the best" when in marginal conditions, not when you really need it.
CT Grand Sport CE (08-06-2017)
#50
Mine go completely black with a quarter edge around them. I mean black as in I can't see anything. Hoping it's not the windshield tint. It's only like 5%. You can barely tell it's tgere.
#51
Yes, this seems "normal", but not right or safe, and this is why I've been complaining about this since 2014.
#52
It's definitely a safety issue when you can't see anything behind you except thru the right side mirror. I need a solution. I may just unplug the damn thing and see if it causes a CEL or error message
#54
I just did the swap on my 2017 1LT GS, to the self-dimming mirror, latest part number is 23408301, $111 from genuinegmpartsdirect thru Ebay. Easy swap, took about 5 minutes. The 1LT harness and connector (the car end) has all the wires already there to make this a plug-n-play upgrade.
#57
#58
The autodim mirror has the same electrical plug (with a few more wires). Other than that, and that it does not have the manual dim flip lever on the bottom, the mirror looks identical. There is no other sensor neeeded, I just swapped the mirror.
#60
but on another subject regarding mirrors. I have searched all over the forum for the postings on how to get your auto-tilting mirrors to come back to your normal settings after backing up but I can't find it. I know it's here somewhere. Does anyone know the path to that post?
