Oil level a bit high....
I have a new Z51 stingray with 100 miles on it. Checked the oil level -- two different times -- and it is a tad above the top dot (i.e., just past the hash marks). Should I remove some oil?
I'm pretty sure you will be alright.
If it really concerns you stop by the dealer and have them do it, this will document the overfill in the event that something were to happen down the road.
I should add that the only reason I'm even asking -- normally I wouldn't care -- is that several people have mentioned oil ingestion problems when oil levels are too high.
It's a fine line between wisdom and paranoia....
I now have the Corvette Tech fill with 9 qts. of MOBIL 1, give me the extra quart. Done this twice so far, didn't need to fill any more ounces.
9.8 quarts says the manual, I'd never put that much in.
If you don't want to lower the oil level now, keep the rpms lower and particularly don't sustain higher rpm's. Shouldn't do that in break in anyway. Vary the speeds but no sustained high speed. Then you'll get it chaged at 500 miles.
One suggestion is to have the dealer (assuming you're having the dealer change the oil) fill with 9 quarts of Mobil 1 and then give you the last quart. Then when you get home and the oil is hot check and fill to 1/2 way in the hatched area.
That is about 1/2 quart below max and 1/2 quart above min.
If you're changing your own oil (as I do) just bought two 5 quart jugs at Walmart for $22 each and submitted for a $12/jug rebate (two allowed.)
That is $2/quart final cost!
My car was 1/8" over the full mark when received. It did pull oil into the intake. (Z51) I now maintain the oil level near the midway mark on the dipstick and have no further issues. I'd siphon some off.
Just curious how did you siphon it out? Did you need to have the car started for a minute so the dry dump tank filled, then shut it down and siphon from the oil fill?
Others have suggested ways to get oil out and if they have done it, it's better than my guess. Since I have tropical fish and plastic aquarium hose, I would use a long length of it, insert it in the tank as far down at least 8 inches and suck on the open end until I saw oil come thru far enough then insert the open end in an empty clear quart bottle. When it looked like enough was out (can always add some back) I'd drive the car get the oil hot and check after 5 but before 10 minutes!
Mine was overfilled at the factory, too, probably a 1/2 qt over full. I tried to siphon/suck out some with aquarium tubing with little luck, probably got 4 oz out in an hour. I finally gave up. It didn't appear to have any lasting effect now at 6,000 miles and two oil changes.
I bought the pump at an auto parts store many years ago. Still works fine.
