Beeps 3 quick times sometimes
Old Apr 9, 2016 | 06:10 PM
Dracla's Avatar
Dracla
Default Beeps 3 quick times sometimes
Why does it happen and why is it very intermittent? Sometimes when I get in, and sometimes when I get out. And it does it not very often.
Old Apr 9, 2016 | 06:32 PM
jknox's Avatar
jknox
Sounds like the typical beeps it does when it thinks you've left the keys in the car and exited...?
Old Apr 9, 2016 | 06:38 PM
Zymurgy's Avatar
Zymurgy
Moderator
If you get out of the car and don't close the door (for example, run back into the house for something you forgot) and then return and close the door, it will beep 3 times because it thinks you closed the door and left the fob in the car. It does not recognize that you are sitting in the seat. It just knows that the door was open and now shut with the fob inside.
Old Apr 9, 2016 | 06:53 PM
Dracla's Avatar
Dracla
Unfortunately I already thought of that and dismissed it since I always close the door when I get out, but occasionally it immediately beeps 3 times...even before I can walk away. Can't for the life of me figure out why.
Old Apr 9, 2016 | 07:00 PM
mschuyler's Avatar
mschuyler
When I get out of the car with my fob to fill it with gas and my wife is still in the car with her own fob in her purse, car goes crazy on me.
Old Apr 9, 2016 | 07:03 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
have the same thing with my wifes '12 GS....no rhyme or reason with one particular FOB....sometimes it beeps sometimes not....could be a week in between ....my 07Z has never done that
Old Apr 9, 2016 | 07:05 PM
Dracla's Avatar
Dracla
Personally I think it is a problem with the car, because I have not left the fob in it, and I don't have time to get away with my driving fob, but it occasionally beeps 3 quick times. Just wondering if anyone else has that problem, or maybe there is a setting I have not found. Any ideas?
Old Apr 9, 2016 | 07:18 PM
Steve Carter's Avatar
Steve Carter
Yes, my 2015 C7 does the same thing, occasionally. By the way, my old C6 did it as well.
Old Apr 9, 2016 | 07:19 PM
RonC7's Avatar
RonC7
Push the button low on the left side of the dash next to the hatch release to turn off the motion detector! (Been there, done that!)
Old Apr 9, 2016 | 07:25 PM
1776DAVE's Avatar
1776DAVE
My 16 is also doing this inconsistently but a bit more then once in a while. . Used. To be once in awhile but is more often now . Not really a bother but a wander why ?
I would not want to turn off the motion senser. .. I let folks think it is an alarm of sorts....
Old Apr 9, 2016 | 07:26 PM
Len44's Avatar
Len44
Great answer. Thanks!
Old Apr 9, 2016 | 08:52 PM
kennedyd's Avatar
kennedyd
Dracla, don't feel like the only one. Once in a while mine does exactly the same thing for no apparent reason (no person or fob left in car, door not left open, ect). Sometimes its when I get in, othertimes its as I exit the car, although it seems to happen more often when I get in. I would say this happens at most 0nce per week. i have a 2016 1LT Coupe.
Old Apr 9, 2016 | 08:55 PM
dvilin's Avatar
dvilin
If the FOB is in your pocket and you are not completely clear of the door jam when you close the door it will beep 3 times thinking you left the FOB in the car.
Old Apr 9, 2016 | 08:59 PM
Len44's Avatar
Len44
Sounds a little like the line from the David Allen Coe song:
"...Had an old trained to attack......sometimes."
Old Apr 9, 2016 | 09:10 PM
funz06's Avatar
funz06
This has come up many times over the past several years------the solution for about 99% of the time------and you can laugh, etc., but I am not pulling your leg-------put the fob in your left pants or jacket pocket. When the fob is in the right pocket of your pants of coat, when you exit, the car sensor picks up on it as if you left the fob in the car----and it will beep 3 times and scare the heck out of you while everyone in ear shot looks at like you are a nut showing off his car.
Mine would always chirp when I exited the car in my garage as it is a narrow one car garage and I could never step far enough away from the car when getting out------with the fob in my right pocket, the darn chirping------when on the Forum someone told us to put the fob in our left pockets we thought he was kidding----but it worked!
I kid you not.
Old Apr 9, 2016 | 10:17 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
that shouldn't be the problem because the fob is still in the car, it just should beep 3 times after he closes his door.
Old Apr 10, 2016 | 07:14 AM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Yes, it's all about proximity. If I linger near the door when I close it, it will triple-beep. Close the door as you're turning and walking away and no beep. The feature can be turned off but I'd rather know if I really did leave the fob in the car.
To Beeps 3 quick times sometimes
Old Apr 10, 2016 | 09:26 AM
Frodo's Avatar
Frodo
I kid you not.
Very interesting observation. I also get the occasional beep, most often when I have sat in the car to retrieve something. My thinking has been that the car sensed the fob when I was inside the car yet didn't, or at least not yet, sensed the fob has been moved to outside the car and the door closed. When this happens the car has not been started and has not been locked, which confuses my logic. It makes sense that left pocket will move the fob farther away allowing the car to sense the fob as being outside the car. I'm not sure how far near proximity communications reaches or how reliable it is when the car is trying to determine exactly where the fob is.
Old Apr 10, 2016 | 09:41 AM
bluez51c7's Avatar
bluez51c7
Every morning I come out from the gym, open the hatch, put my gym bag in, close the hatch, open the drivers door and get the beeping, not the three beeps, that are intermittent, but constant bong, bong bong. I get in, start the car and it stops.
I get used to it, like my dog wagging her tail, it just happens.
Old Apr 10, 2016 | 09:43 AM
funz06's Avatar
funz06
I know it sounds crazy, but it really works. The solution is so simple, it just sounds too good to be true. My car would beep close to 90% of the time when I was getting out of the car in my garage when the fob was in my right pocket, but subsequent to moving it to my left pocket----maybe it chirps 2-3 times a year, tops-----and that is usually because I turned my left hip forward toward the hood versus backward, toward the trunk when exiting. And before the switch I would get the beeps 25% to 40% of the time outside the garage, and now, maybe once or twice a year. Like another post noted, I will get the beeps when I get out and leave the car door open, and run back into the house; pump gas; or otherwise walk away from the car-----then come back and close the door-----but very rarely now when just getting out normally.
