Clutch replacement cost???
Old Apr 10, 2016 | 09:21 PM
emsguy's Avatar
emsguy
Default Clutch replacement cost???
anybody know the cost of replacing the M7 clutch? parts? labor? don't need one yet, but from what I am hearing, I better start saving now.
thanks.
Old Apr 10, 2016 | 09:40 PM
mitchydkid's Avatar
mitchydkid
Based off C6 cost... prolly 6 bills for a stock clutch and 12 for labor at the dealer. You can ask around and find a speed shop that will do the labor at half that cost.
Old Apr 10, 2016 | 10:00 PM
Mike02z's Avatar
Mike02z
If you have Z51 you can expect ~24 hours labor. The C7 with Z51 is much more difficult than the C6. I had my stock clutch replaced last season. My installer said it was not difficult just time consuming.
Old Apr 11, 2016 | 06:37 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Really 3 days of labor for one person? That's pretty shocking.
Old Apr 11, 2016 | 07:00 AM
raylo's Avatar
raylo
What about the Z51 makes it more difficult than base? If this is true I am going to limit my use of launch control and avoid the strip to make mine a "lifetime" clutch.
Old Apr 11, 2016 | 07:48 AM
SRQStingray's Avatar
SRQStingray
thanks.
If you have a high performance car, you should expect a clutch to be expensive to replace. Just like tires and brakes, it is an expendable. You have to pay to play.
Old Apr 11, 2016 | 08:10 AM
raylo's Avatar
raylo
I don't mind paying to play, but I do mind bleeding to play! ;-)
Old Apr 11, 2016 | 08:34 AM
nmerhaut's Avatar
nmerhaut
thanks.
Why not call your dealer and get a quote as a base price?
Old Apr 11, 2016 | 10:38 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm, just checked the 2014 Service Manual. Can see why the cost is high and higher for the Z51! Will probably be higher than the C6.
First they need to remove the trans, rear and torque tube. Lots of things to disconnect.
In a C7 Z51 that includes trans cooler and dif cooler lines and the sway bar. Base car doesn't have these. May be some extra with the ~3000 psi electric pump for the eLSD.
The C7 has a dual disk clutch so the parts will be more than the C6. Assume it would be logical to use a new throwout bearing assembly and bleed that system.
Would sure want to have someone who did it before I was the first! Always learn from the first try. Like most instruction manuals there are usually a few things not covered or covered poorly!
Another good reason to sell my September 2013 built Z51 C7 and buy a 2019 GS!
Old Apr 11, 2016 | 10:44 AM
raylo's Avatar
raylo
Agreed, you'd want to have a seasoned tech do this. Get something in wrong, or forget a bolt or something then have 3 more days work to correct it. This could be a nightmare job for a non-expert.
Old Apr 11, 2016 | 11:10 AM
Woodson's Avatar
Woodson
thanks.
I haven't heard of any clutch issues. Links?
Old Apr 11, 2016 | 11:17 AM
raylo's Avatar
raylo
No issues that I know of. Just us guys that tend to keep cars a long time wondering what's ahead.... Although there are undoubtedly some folks here getting blowers and either wearing out and/or looking to upgrade clutches.
Old Apr 11, 2016 | 11:19 AM
Boiler_81's Avatar
Boiler_81
The only mention of clutch issues I have heard of was at Spring Mountain. They said they had to replace a few until they started teaching people to start rolling with out applying throttle until the clutch was fully engaged. It's simple to get this car going without slipping the clutch. I am anticipating never replacing it.
Old Apr 11, 2016 | 12:40 PM
Mike02z's Avatar
Mike02z
My shop said there was a lot more involved with the coolers etc. They had done a lot of other C7's but said my Z51 was much more time consuming. I paid a set price so the shop had no reason to keep the number of hours to themselves.
Old Apr 11, 2016 | 01:52 PM
DickieDoo's Avatar
DickieDoo
There was a show... TWO GUYS Garage that showed how they did a clutch on a C5/C6. A Z06 as i recall, so should be no different for a C7, Z51 or not ( IFF you do not drop the torque tube /tranny ) They used a series of jack stands under the driveline so they did not have to disconnect all the cooler lines, I believe there should be enough flexibility in the lines to do that.
Old Apr 11, 2016 | 03:40 PM
fsvoboda's Avatar
fsvoboda
thanks.
Depending on how you drive, you might never get to clutch replacement, particularly given the rev matching and great torque (thus less shifting) of C7. I drove manuals from mild to wild for about 25 years and never replaced a clutch, even on a vehicle with 165,000 miles.
That said, I've heard as a rule of thumb, look at the cost of an auto transmission option on a car, and figure that is what it's going to cost for your clutch, more or less.
Good luck.
Old Apr 11, 2016 | 09:53 PM
emsguy's Avatar
emsguy
that's my plan. just wanted forum input to keep my dealer honest.
To Clutch replacement cost???
Old Apr 13, 2016 | 10:01 AM
wgood's Avatar
wgood
thanks.
Is it squeaking because check out my post !!!! There is a service bulletin and it is a 2 day job !!!! Wayne
Old Apr 8, 2017 | 11:54 PM
Z51 John's Avatar
Z51 John
Just a question, wouldn't it be easier to remove the engine?
Leave the torque tube and tranny in.
Old Apr 9, 2017 | 12:32 AM
05XLRtoC7_San Diego's Avatar
05XLRtoC7_San Diego
thanks.
According to Jimmie Johnson Chevy in San Diego- it's $3500 for parts and labor to install a clutch in a C7.
Someone had fried their clutch on a 2014 C7 at 16k miles while at a drag strip, and they showed me the invoice of what he was charged
