Cags
Old Apr 19, 2016 | 09:03 PM
Dave Kitch's Avatar
Dave Kitch
Default Cags
I just purchased a 2015 coupe 2LT MN7 with electronic ride control and rev matching. I was told that the 1-4 skip would not occur if you were in the sport mode. However it occurred a few times.
I then set the mode to S and set rev matching on. I must have tried 10 times to start out slowly and get the 1-4 skip to work. But it did not.
Decided not to tear away the insulation around the trans wiring harnesses to install the eliminator.
Regards,
Dave K.
Old Apr 19, 2016 | 09:15 PM
Fcal's Avatar
Fcal
Removing the insulation (plastic cup) is no big deal. You just zip tie the eliminator to the housing.
My C6 had no insulation and I ran that setup for 5 years.
Old Apr 19, 2016 | 09:21 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Skip shift occurs in any mode. It's never even kicked into play when I've been driving. Like you, I forced mine so I would know what it feels like. It's possible the prior owner already installed the eliminator if you can't force it.
Old Apr 19, 2016 | 09:45 PM
Dave Kitch's Avatar
Dave Kitch
The previous owner did not!
Old Apr 19, 2016 | 10:11 PM
DBLXX's Avatar
DBLXX
Hey Dave -
Do you have a question?
My car does it all the time - but I shift low and drive slow. I just double pull and it slides right into 2nd.
I'll be installing the CAGS - once the car is on the lift - takes about 30 seconds to install.
Old Apr 20, 2016 | 09:28 AM
Dave Kitch's Avatar
Dave Kitch
Thanks but no further questions.
Dave K.
Originally Posted by DBLXX
Hey Dave -
Old Apr 20, 2016 | 11:35 AM
dr_gallup's Avatar
dr_gallup
Can you just replace the fuse with a resistor like you can for the C6? Very easy and you can change it back in 30 seconds if you want.
To Cags
