Curb camera
Old May 10, 2016 | 12:45 PM
fredl11's Avatar
fredl11
Default Curb camera
Ok Curb Alert is driving me nuts!. all of a sudden it has gone on a chirping spree AGGGGH. I've done the setup and have given up.
I was interested in Navtool but after the SNAFU and resulting software updates info I am not to sure about that product.
Anybody know of another way beside removing whole interior and replacing existing radio??
maybe just a camera and a small video screen with an on off switch to use when pulling into a curb?
Old May 10, 2016 | 12:59 PM
dosamp's Avatar
dosamp
Check out: https://www.corvetteforum.com/forums...very-long.html
Old May 10, 2016 | 01:28 PM
robert miller's Avatar
robert miller
Really man navtool is great now from the 3.1 update on it. It works 100% and just like it should work..
Old May 10, 2016 | 02:24 PM
Mister Big's Avatar
Mister Big
Oh, crap! I was about to pull the trigger for one of these. How long did you have it before it went bonkers?
Old May 10, 2016 | 03:38 PM
123sugey's Avatar
123sugey
Dig
Are you sure it's aimed correctly ?
Old May 10, 2016 | 03:53 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
NavTool works like a champ. Every time I use it, I smile.
Elmer
Old May 10, 2016 | 04:32 PM
SCorvette08's Avatar
SCorvette08
i bought small camera and a trasmitter for both 80 amazon then you down load GOVue
on phone and thats it works great some comanys put both devises togeter and charge up to 150 but its just the same if you pick the parts separate mine works perfect it works through bluetooth/wifi
Old May 10, 2016 | 08:14 PM
Adoggy Phizzle's Avatar
Adoggy Phizzle
I'll bet dollars to donuts your negative screw is loose causing it to lose contact. Check and tighten and you're problem Will go away. This is from experience .
Old May 10, 2016 | 08:28 PM
capecodvette's Avatar
capecodvette
I installed Curb Alert on my 2013 GS. No issues. If you have issues, try calling the supplier and/or company. I did, they were extremely helpful. The system does work.
Old May 10, 2016 | 10:15 PM
BigRick1960's Avatar
BigRick1960
Does it chirp in evening or first morning light when front end of car facing the sun?
Old May 10, 2016 | 10:21 PM
RonC7's Avatar
RonC7
As noted above, check your ground connection and the crimped connector on the ground wire. I had a frequent chirping until I found the bad connection. No further issues for almost 2 years.
Ron
Old May 10, 2016 | 10:55 PM
Adoggy Phizzle
Ron
Boom!
Old May 11, 2016 | 08:56 AM
fredl11's Avatar
fredl11
Hmm I wonder I'll give it a go.
Thanks for all the responses
Old May 11, 2016 | 09:25 AM
purple heart's Avatar
purple heart
Check for bird nests lately?
Old May 15, 2016 | 06:07 PM
Maxpowers's Avatar
Maxpowers
I know I'm in the minority here but I have the front cameras and don't use them. I just learned where the front of the car is. It's not a long car.
Old May 15, 2016 | 08:18 PM
eboggs_jkvl
Moderator emeritus
I see by your avatar that you don't have a splitter? Get one and keep saying that...
Elmer
Old May 15, 2016 | 10:16 PM
PapaLeo67's Avatar
PapaLeo67
Really?
I use them every time I pull up to one of those tall concrete parking stops. My daily driver is a truck, and I never have been so close to the ground. I will be so pissed if I scrape a curb.
To Curb camera
