Thanks for the quick replies. I called GM Roadside Service to inquire about making sure that if I need a flatbed in the morning they will send one that knows how to load a Corvette without damage. Is there a way to get the tranny out of Park with a dead battery? Otherwise they will have to lift the rear wheels, right? Not looking forward to this. I sure hope I can drive it to the dealer tomorrow.
I'm guessing you don't have a service like AAA. Back a few years ago when my C6 batt. died, it was really dead. Maintainer would've taken maybe 1-2 days (yours could be better but I wouldn't count on it). Service came--he had a huge double batt. to start cars and mine started right up and it was really dead.
Don't know if car's charging system is still "undersized," but C6 was. BG told me that continuous short trips, couldn't keep up with the batt. discharge. His suggestion was to not try charging by driving but that if I did, it'd take 30-45 minutes, at 1500 rpm constant, or above.
If your charging batt. is strong, try it. If not, either tow it or get a service in with a big batt.
Hope it turns out well for you.
I dropped my AAA membership last year. If the battery is still dead in the morning after 12+ hours on the CTEK I'm going to try to jump start and drive to a dealer about 15 miles away. I drove to and from the Bash, over 1300 miles, with several short trips while in BG with no issues other than my infotainment system locking up one evening. After the car sat for about 30 minutes all was back to normal. Drove home and parked the car for about a week. Took one short trip of maybe 10 miles yesterday and then battery was completely dead this morning. Very strange. I hope it's just a bad battery.
I'd agree; it's probably either a bad batt. (most likely) or something in the electrical/charging system. Your description of the use of the car is almost opposite of short trips-only.
One last thing: do you have anything wired into the car like a Blendmount for a radar detector, a different stereo/nav, something else that's non-stock?
I'd just buy the battery maintainer thing and plug it into the trunk cigarette lighter for one night and try it in the morning to get the alternator to charge it. If that doesn't work I'd pull the battery out and get it tested at autozone before getting a dealer involved
FWIW, It's not as easy as with a C6 to "pull out the battery." In fact even having AAA jump start could cause a ripped carpet! I'll explain:
To access the battery you have to pull out the right rear of the carpet, which is very tightly held. Check the Owner's Manual but I'd suggest one thing it does not mention. To avoid ripping the carpet unclip the plastic wheel cover. There is a clip about 3 inches up from the carpet. You can actually do it with your fingers but a plastic trim tool or even a small paint scraper could be used. No need to remove the fasteners from the top, just pull it out a few inches while you pull out that section of the carpet.
Getting the battery out is also difficult, you can use a special lifting tool after removing the foam cover and the large power board and wires connected to the positive terminal.
If replacing with a AGM battery, as I plan this September (if not sooner, it will be 3 yrs old and has had a low voltage since new) the battery configuration must have recessed terminals to have the power board fit. An Optima will not.
There have been forum posts about the carpet ripping and expect an AAA person that has not jump started a C7 could easily cause a rip.
It's been on my CTEK all night and I'm going out in a few minutes to see if it has any charge at all. I do not have any accessories installed in the car other than my ipod which is connected to the USB port behind the screen. I really don't want to remove the battery myself so if it hasn't charged enough to start the car I will try to jump start it and drive to the nearest dealer which is about 15 miles away.
Update at 7:50 am: After over 12 hours on the CTEK battery is still completely dead. CTEK unit is telling me that the battery won't accept a charge. I was able to pull back the carpet to access the battery terminals. I will try to jump start the car later today when my wife gets home from volunteering for Hospice. I've jumped many cars before but is there anything special about a Corvette. I don't see anything in the rear hatch that I can use for a ground so I guess I will connect the jumper cables directly to the positive and negative terminals of the dead battery. Any other issues I should be aware of? Thanks.
The people AAA contract out to do the roadside service are not always the best. I had an issue with my C-6 and the guy they sent out was clueless! He screwed around trying to do a diagnosis that didn't work. Finally I had to show him how to jump the battery.
I haven't verified this personally but my museum delivery guy warned me that the port behind the screen is always "hot" for charging purposes so over a long period of time an accessory here can run down a battery.
In your case it sounds like your battery has an open cell and if so be careful with jump starting. Among its other functions the battery serves to absorb voltage spikes so you want to minimize the chances of that if the battery does have an open cell because it won't absorb spikes.
Before trying to jump start it if you have a test meter measure the voltage across the terminals and if it is extremely low (9 volts or lower no load) I would be risk averse and see if the dealer will send a tech out to replace the battery. If you are going to jump start a car with a defective battery a jump pack would be far safer than a high current charger/starter or another vehicle because you can securely make the connections and then turn the jump starter's power switch on without fear of sporadic connections which create spikes.
Most of the time jump starting a vehicle causes no problems but with an open cell battery in a car with the level of electronic integration of the C7 proceed cautiously. Also be aware that if you use a high current charger or another vehicle to provide power to the battery if it is able to accept a charge it will likely do so at a very high current level which is the perfect environment for outgassing hydrogen so do this in an open environment.
Just talked to Roadside Assistance. They cautioned about jumping the car myself. I have an appointment for a technician to come and try to start the car or tow it to my dealer. Crap, this is not what I wanted to do but life goes on.
HMM, I don't think the port behind the screen is hot when the car is off but I could be wrong. At any rate you have my scared to jump the car now as I think the battery is just about completely dead as I have no interior lights, nothing. In fact when I connect the CTEK unit I get a series of noises from under the hood at the left front. Sounds like some sort of motor or switch. Not sure what this is. At this point I may have to call for a flatbed, not what I wanted to do. I will also call the dealer and ask their advice.
Dealer can't or won't send a tech to my house, too far away. Called Roadside Assistance and have an appointment for a service call after lunch. Not looking forward to this but what can I do. I specifically told her the car was a brand new Corvette and it was in my garage. She assured me they contract with "professionals" that know what they are doing. Yeah, right.
Hook up the dead battery first. Then the positive to the good battery and then find a ground source away from the good battery . All safe and no problems.
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
I had this happen to one of our C5's and a C6. Both times I called my dealer and explained the cars were dead in the garage and I didn't really want a tow. So both times I just removed the battery and took it to the dealer. Both had dead cells, got a new one under warranty and returned home and installed it. Good luck with yours.
I may do the same IF I can get the battery out of the car. If I jump start it will I do any damage driving about 10 miles with a dead battery and will the engine keep running?
After it is running, the alternator is the source of power. Battery not really doing much after the engine is running. Get it running and go, you won't hurt anything.
Once power is restored to the car (jump start) wait a few minutes for the car's electrical components to power up or you will only get a click, click when you hit the start button. I had my car powered down to reboot the computer and I had to wait a few minutes before the engine would crank/start.
Exactly what happened. I'm waiting on Roadside Service now. I hope they can get it started. I really don't want it to be flatbedded unless this is my only option.
