How to fix code DTC P2096
All was fine until I added the Borla x-pipe. I am getting the CEL coming on with the code P2096 post catalyst fuel trim system low limit bank 1. The dealer checked all the sensors and they are working correctly. It seems that the post catalyst sensor is not liking the way the exhaust gas is either flowing or the composition or both.
Has anyone else had this issue and how did you fix it, other then removing the mods?
