Map light removal instructions?
Old May 30, 2016 | 08:10 PM
SharkGrayStingray's Avatar
SharkGrayStingray
Default Map light removal instructions?
For the life of me, i can't find the removal instructions for the map lights, to swap them for led's. Can anyone help me out? I'm pretty sure i swapped them out for white led's, but now want to change them to red and i can't get them off!! Thanks guys
Old May 30, 2016 | 09:00 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
They already are LEDs and they aren't a standard bulb. Plus, it's a real pain in the ***. They take those tiny little bulbs, I can't even point you in the right direction to look for them.
You can pry the cover off, then the bulbs are in a fixture. To get it back on, you have to remove the cover in front of the rear view and push down on them from the top with your finger to snap the fixture back into place.
Old May 30, 2016 | 09:04 PM
SharkGrayStingray
damn, that sucks!! i thought i changed them, but i guess i only changed the hatch bulbs...
ill check the manual, but do you know off hand if the map lights can be disabled when the doors open? I just put red led strips under the dash and ill change the hatch to red but would love to disable the map lights... thanks for the input.
Old May 30, 2016 | 09:22 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Sorry, I'm not sure how to do that. You could unplug the fixtures, but that's not a very good solution. Maybe someone that knows will chime in!
Old May 30, 2016 | 09:54 PM
SharkGrayStingray
i just took the cover off to see if i could use floss to pull the bulb out, but i couldn't even get the floss around the bulb. I am afraid of breaking the bulb in the fixture then having a major headache so i just gave up. Getting the cover back on was a pain like you said. I pulled from the bottom instead of pushing from the top like you suggested, it was a pain to say the least. Ill live with it white lol thank for the input pal!!
Old Sep 16, 2016 | 05:50 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Sucks ........ I so wanted to change the right side to red for night driving ........
Old Sep 16, 2016 | 08:29 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
You could put a piece of red film over the lens.
Old Sep 16, 2016 | 09:00 PM
witch hunt's Avatar
witch hunt
good idea---just about to suggest that myself Rooster
Old Sep 16, 2016 | 10:58 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
lol ........ Went to wally world and bought the 3M taillight repair tape in red in between posts ............. More than enough to do both Corvettes and the smartcord heads for the Escort radar detectors.
Old Dec 2, 2021 | 09:17 PM
Trucker702's Avatar
Trucker702
4th Gear
Default You can tint them red
Buy red self adhesive film from amazon and tint them.
Old Nov 13, 2025 | 09:41 PM
Chalksac's Avatar
Chalksac
1st Gear
Default C7 corvette dome/map light reinstall
I don’t want to get into why I even took the plastic cover off in the first place but I’m a certified mechanic it’s my job it’s what I do everyday. And this dome light was the worst time I’ve ever had with an interior light so I wanted to share my trick for anyone trying to put that stupid plastic cover back on. What I recommend is taking the sun visor mount off it’s just one t15 screw then use a straight pick from the sun visor mount hole to apply pressure on top of the light housing, while you mangle the plastic cover for 30 minutes. I recommend clipping the side furthest away from the button first then you have to line it up perfectly and apply pressure on the pick forcing the house downwards simultaneously pressing the cover on. Good luck everyone that took off their cover trying change their bulbs!
Old Nov 15, 2025 | 12:19 PM
frankbicknell's Avatar
frankbicknell
Can someone share a photo from a nighttime view with the tape on?
Old Nov 15, 2025 | 02:51 PM
9sec's Avatar
9sec
remove both visors. 3 Torx each. unplug them store out off the way. from the door sill pop the sill off up to the a pillar. then twist the rear view mirror off and unplug it or leave it hang. pop the header off with the plastic piece attached and unplug as needed. now you have the entire piece off you can set on a bench or table and work the lights . ive done this twice and have a new in box alcantara header and plastic piece for sale if you break yours. the lights come out from the inside. I dont think the bulbs come out I think you swap the entire assembly if the bulb blows
To Map light removal instructions?
