I've read (and watched) conflicting information regarding the material used in the base C7 hood. Is it fiberglas or CF?? It's certainly light enough to be CF, but guessing it's fiberglas due to $$.
The hood is carbon fiber and so are the roof panels minus the transparent.
There is no conflicting info from Chevrolet - It is Carbon Fiber!
If you're interestested this is what was said in 2013 about the Stingray: "the new baseline Corvette is also the first production car to feature structural, Class A carbon fiber-reinforced plastic (CFRP) body panels produced via a new out-of-autoclave "pressure-press" technology."
In addition the Corvette has not been made out of "fiberglass" for many years! It's made from SMC (Sheet Molding Compound or Composite, whichever you like to call it!) It has some fiberglass in the composite. The 2016 Corvette uses TCA Ultra Lite, a Class A body panel material (SMC), results in a 20 lb (9 kg) weight savings on the Stingray Coupe model. This is the first production use of CSP’s Ultra Lite advanced composite. For 2016 it now has significantly reduced the density– from 1.9 specific gravity for the 2013 model year, to 1.6 specific gravity for the 2014 model year to 1.2 for the 2016 model year. It uses treated glass bubbles to replace some of the Calcium Carbonate filler, resulting in a lighter density material.
Note the density of water is 1, it's getting close to floating!
Not density of 1, specific gravity of 1 for water.
I believe 1972 was the last year for the fiberglass.
