Fog inside headlight
Old Jun 22, 2016 | 08:20 PM
probono's Avatar
probono
Default Fog inside headlight
My 2015 C7 has developed fog inside the driver side headlight. Drove about 150 miles today with the headlights on, and it's still there. Has anyone else seen this before?
Ken
Old Jun 22, 2016 | 08:44 PM
Bucknut2006's Avatar
Bucknut2006
You have a crack or failed seem. Dealer should swap it out if it isn't due to damage.
Old Jun 23, 2016 | 07:41 AM
Frodo's Avatar
Frodo
This can happen. I have it as do others who've posted before in other threads. The lights aren't sealed, nor can they be. It gets hot and cold inside the light, air pressure must be vented. It breaths in moisture and dust as it does this.
Maybe the dealer will replace it, you'd think it would be covered. Perhaps they'll see it as normal wear and tear.
Good luck with it in any case.
Old Jun 23, 2016 | 07:43 AM
probono's Avatar
probono
Just strange that the passenger side is just fine....
Ken
Old Jun 23, 2016 | 07:45 AM
CriticalmassGT's Avatar
CriticalmassGT
They will replace it. I've seen this happen before. If it were both headlights and went away with the lights on, I'd call it a humid day and leave it at that. But with one headlight and the condensation not dissipating a seam has failed on the light. It happens. The lights are literally glued together and the glue can fail if it isn't applied properly at the factory.
Old Jun 23, 2016 | 07:59 AM
mikez06's Avatar
mikez06
Yes, we had the same thing in our new Viper once.
Definitely under warranty, and also just one headlight did it.
Swapped it out and it was fine after that.
Old Jun 23, 2016 | 09:12 AM
probono's Avatar
probono
Off to the dealer next Wednesday for this issue and 3rd oil change...also going to make sure they check the rear dif level...drove to Geneva on Seneca Lake yesterday; beautiful day, and great fun driving the car. I LOVE two lane country roads with an occasional slow car which needs to be passed
Ken
Old Jun 23, 2016 | 10:03 AM
Red C8 of Jax's Avatar
Red C8 of Jax
I have a 2015 and had my rear diff checked at my last oil change and they said it had to be topped off. They didn't say it was low. Go figure. I also had to wait an extra hour for a real mechanic to check the rear diff. Good that you are going to have yours checked.
Old Jun 23, 2016 | 02:44 PM
Larry/car's Avatar
Larry/car
Foggy headlights have been around since the C6 came along. Fog comes and goes depending on the weather/humidity.
Old Jun 23, 2016 | 04:30 PM
DickieDoo's Avatar
DickieDoo
They will replace it under the 3 year bumper to bumper warranty BUT not necessarily if you are on extended warranty so get it done fast.
To Fog inside headlight
