Locked inside car=A8
Old Jun 25, 2016 | 02:14 PM
vdavenp802's Avatar
vdavenp802
Default Locked inside car=A8
I parked the car and tried to get out but was locked in. Car seemed to be in 'acc' mode as radio was on, and DIC said to step on brake to start.
I discovered I had turned the car off when in 'R', not park.
A restart and shutdown with shifter in park fixed the problem.
Old Jun 25, 2016 | 03:01 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Ok then, now moving right along.......
Old Jun 25, 2016 | 03:02 PM
dvilin's Avatar
dvilin
That would be almost locked in.
Old Jun 25, 2016 | 03:19 PM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
You are never locked in your car.
Old Jun 25, 2016 | 03:27 PM
jimmyb's Avatar
jimmyb
To coin the oft used phrase: "Car is operating as intended"
If you shut down in ANY gear other than Park, literally EVERY modern car will NOT allow you to remove the key (for cars with keys) or keep the car locked (as my wife's 2014 keyless Impala will do. I just tried it and it did the same thing as the OP's Corvette). How this is a "problem" is a mystery to me.
Jimmy
PS. BTW, as has been pointed out, you are NEVER locked in the car. The levers down by the seat on the floor are manual releases for the door should you lose electric power (or shut down in reverse).
Old Jun 25, 2016 | 03:44 PM
L8ter's Avatar
L8ter
at this thread.
Old Jun 25, 2016 | 04:10 PM
Frodo's Avatar
Frodo
Thanks for the heads up. I've caused myself a couple of problems over the past 16 months of ownership. Live and learn.
Old Jun 25, 2016 | 04:49 PM
TyBoo's Avatar
TyBoo
I find myself doing the same once in a while. It is usually at the gas pump. Even when going through the restart and proper shut down the door button still doesn't work and I have to push the unlock button to open the door. Since I am in Oregon where the gas is pumped by an attendant this is especially frustrating for an old feller like me who wants to get the filler door open before the gas guy starts banging on it.
Pay no mind to the folks who are so much smarter than us and never make a mistake. The world needs normal people, too.
Old Jun 25, 2016 | 04:50 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Alrighty then.
Old Jun 25, 2016 | 05:30 PM
Larry/car's Avatar
Larry/car
I was cleaning inside windows on my C6 with fob on the floor, I closed the door, you guessed it locked in. I grabbed the emergency door release and pulled, (discovered you don't have to pull just lift) any harder and I would have ripped the lever from the car. On an airplane, emergency releases require a pull.
Old Jun 25, 2016 | 06:01 PM
AceG's Avatar
AceG
I was locked in once.. then i hit the unlock button and walah im free
Old Jun 25, 2016 | 07:02 PM
NinjamanZ51's Avatar
NinjamanZ51
2017 C7 of Year Finalist
This forum never ceases to amaze...
Old Jun 25, 2016 | 08:00 PM
dmvette's Avatar
dmvette
I have nothing to offer, just getting in to see what other humorous remarks will be made.
Old Jun 25, 2016 | 08:36 PM
thegame's Avatar
thegame
Hey guys something is wrong with my car it will only drive backwards not forwards. However I was in reverse.
Old Jun 25, 2016 | 08:41 PM
RonC7's Avatar
RonC7
Did you call BlondeStar?
Old Jun 25, 2016 | 08:43 PM
themonk's Avatar
themonk
I forgot my fob in my house one day and I was locked out of my car.
Old Jun 26, 2016 | 08:55 AM
tail_lights's Avatar
tail_lights
Y'all some cold blooded *****.......
To Locked inside car=A8
Old Jun 26, 2016 | 09:17 AM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
Or, just put it in Park, and unlock the door.
Old Jun 26, 2016 | 10:53 AM
jimmyb's Avatar
jimmyb
Originally Posted by RonC7
Perfect!
Old Jun 26, 2016 | 10:55 AM
jimmyb's Avatar
jimmyb
If ever there was a thread BEGGING for the Corvette forum humor, it's this one. I am very impressed by the restraint exhibited (so far) by the members.
Jimmy
