Oil Pressure
Old Jun 27, 2016 | 10:10 AM
alamo1974's Avatar
alamo1974
Default Oil Pressure
I have owned a C5, 3 - C6's and have a 2016 C7. I have never had oil pressure as low 30-32 psi at 70 mph. After engine has warmed up it will drop from almost 40 to 30-32psi. Is this normal.
Old Jun 27, 2016 | 10:31 AM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Speed doesn't determine oil pressure, RPM (and other factors) does. The old thumb rule of 10 psi/1,000 RPM still holds true. Depending on what gear you're in 30 psi at 70 mph is not a problem.
Old Jun 27, 2016 | 10:36 AM
NSC5's Avatar
NSC5
The LT-1/LT-4 use a different style oil pump that is designed to provide a lower pressure under normal operating conditions to increase fuel economy. When called for higher flow/greater pressure is provided. If there is an issue with the controller for the low vs high rate the pump will default to high rate for safety.
Old Jun 27, 2016 | 01:36 PM
kp's Avatar
kp
From an old GM press release on the C7 LT1:
Oil control:
The heart of the all-new Gen 5 small block oiling system is a crank driven, variable-displacement, dual-pressure oil pump, which continuously adjusts oil flow to maintain proper oil pressure at the bearings. Working with the AFM system, the variable-displacement pump keeps oil pressure "efficient" during low RPM operation and ramps it up to higher pressures as RPM and demand increases. The Corvette engineering team has seen a 7-10psi decrease in oil pressure thanks to the new system when compared to the LS family, and has revised the oil pressure sensor location, moving it from the back to the front of the block.
Old Jun 27, 2016 | 02:34 PM
alamo1974's Avatar
alamo1974
Oil control:
Thanks to all, this forum is great for information.
Old Jun 27, 2016 | 09:48 PM
user051728's Avatar
user051728
Yea, this new pump design fixes the issues with the previous pump that goes back to the late-90's and the LS1
Want to see issues with the old design, Google Camaro LS3 Oil Pump Failure.
Old Jun 28, 2016 | 02:34 AM
Maxie2U's Avatar
Maxie2U
I'm having trouble shall owing at 6000 RPM oil pressure will be 60 PSI, but I will check that out on my next drive.
Old Dec 4, 2020 | 05:30 PM
robert miller's Avatar
robert miller
Default ttt
I think here you are looking at what the older motors should be at, not the LT motor... Robert
Old Dec 4, 2020 | 09:56 PM
Hopefully he got it figured out since this thread is from 2016.
To Oil Pressure
