2016 base Corvette automatic
Old Jul 25, 2016 | 05:50 PM
badboy01's Avatar
badboy01
Default 2016 base Corvette automatic
I have a noise coming from the left rear like a humming sound .took it to dealer and they say that is the cooling fan for the transmission. problem is the fan is on quite a bit when windows are up. any one else having this problem?
Old Jul 25, 2016 | 05:58 PM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
You might want to check out this thread that a number of us are posting on. We are hearing the sound, usually from the left rear at about 1200 to 1500 RPM with a light load on the throttle. If you remove your foot from the gas pedal, the noise goes away..... we are all thinking it is in the drive train as GM has replaced several folks exhaust systems etc without luck.
After reading, please let us know if this sounds like you and join in the thread which is well documented below...
https://www.corvetteforum.com/forums...ssionally.html
Old Jul 29, 2016 | 09:06 PM
badboy01's Avatar
badboy01
no this noise is a fan that cools the transmission on the rear left hand it comes on and off hear it when you are at a stop when windows are up again this a fan not a wobble sound anyone else have this problems or hear it at a stop. because I don't belive the dealer.
Old Jul 29, 2016 | 09:49 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Take it to a different dealer if you can.
To 2016 base Corvette automatic
