Flat tire
Old Jul 26, 2016 | 10:35 PM
cleahy100@gmail.com's Avatar
cleahy100@gmail.com
Default Flat tire
i have a nail in my rear tire Z-06, I have Sport cup 2 tires and the nail is the middle of the tire, drove about 10 miles before I could put air in. it is loosing it pretty fast any suggestions. can it be repaired or just get a tire and if so where the dealer or a tire shop ?? help
Old Jul 26, 2016 | 10:50 PM
robertbruce's Avatar
robertbruce
I plugged my tire on my 15 Z06. Worked great.
Old Jul 26, 2016 | 10:51 PM
owc6's Avatar
owc6
Location?
Would be helpful.
Old Jul 26, 2016 | 10:52 PM
cleahy100@gmail.com
Originally Posted by owc6
Location?
Would be helpful.
long island ny
Old Jul 26, 2016 | 10:53 PM
cleahy100@gmail.com
Did you do it or have the dealer do it ??
Old Jul 27, 2016 | 12:34 AM
driver9's Avatar
driver9
Remember that if it is plugged it loses its speed rating. It may still be fine at high speeds, but you're not supposed to run it at high speeds anymore.
Old Jul 27, 2016 | 03:52 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
If in the center should be possible having one "plug/patch" done on the tire. However that requires removing the tire from the rim. Even our large Chevy, BMW, Mercedes dealer in town has wide run flats changed/repaired by the only place I let touch my tires, the local Firestone dealer. They have 12 bays, some 20 mechcanics and a touch-less tire machine. Even then only ~2 of the mechcanics do the wide low profile tires. It's not easy! Check to see that where you plan to take it has the right equipment and skills. Even a trained C7 mechanic would not do enough tire changes to match someone who does more frequently, IMO.
Check the Tirerack website and see who they have as an authorized installer in your area and call a few and ask about your tire size. You can also check their price for a new tire if that is needed.
Plug Patch
Old Jul 27, 2016 | 06:37 AM
Millerrock's Avatar
Millerrock
Replace it!! Don't risk your life!
Old Jul 27, 2016 | 06:54 AM
Cur's Avatar
Cur
Lol what?
Plug it, it'll be fine.
Old Jul 27, 2016 | 07:03 AM
gwalsh88's Avatar
gwalsh88
Originally Posted by Cur
Lol what?
I have plugged my run flats multiple times on my two C6s and went on to drive them for another 15,000 to 20,000 miles until they were worn out normally. No issues at all.
Old Jul 27, 2016 | 07:05 AM
67435animal's Avatar
67435animal
I had the same problem 6 months ago and had the tire repaired. $30. No problem since
Old Jul 27, 2016 | 08:11 AM
Millerrock's Avatar
Millerrock
If your an old fart go ahead, 90% of these cars don't see over 90mph anyway, I'm not a cheap a$$ so I never plug any tire.
Old Jul 27, 2016 | 08:12 AM
robertbruce
I did it.
Old Jul 27, 2016 | 08:17 AM
Walt White Coupe's Avatar
Walt White Coupe
Center of tire, just get it plugged properly with this:
And for the reduction in "speed rating', is a maximum of 130 mph steady going to cramp your style?
Old Jul 27, 2016 | 08:20 AM
C7Joy's Avatar
C7Joy
It should be okay to plug if the puncture is in the center of the tread.
Old Jul 27, 2016 | 09:14 AM
Foosh's Avatar
Foosh
You may not be a "cheap" one, but your post makes you sound like one.
With a puncture in the middle, a proper patch applied to the inside of the tire will be fine. It will be entirely safe for street use.
Old Jul 27, 2016 | 09:20 AM
dvilin's Avatar
dvilin
Center of the tire plug/patch and all is good.
To Flat tire
Old Jul 27, 2016 | 09:48 AM
4thC4at60's Avatar
4thC4at60
How old are you? 17 and driving your daddy's car?
I've been driving sports cars since 1960.
As others have said I've plugged tires and gone another 20,000+ miles -
Oh, and I may be 74 but both my C7 and my Ferrari regularly see XXX in speed...
Old Jul 27, 2016 | 10:30 AM
PNorris's Avatar
PNorris
Default uuuhhh
It's a run flat. Worst case scenario is the plug comes out and the tire slowly loses air and guess what . . . . it can run flat. How about that. Plug it, I just plugged mine yesterday. Damn rain storm pushed all the nails on the shoulder into the street. I had two nails in one tire!!!
Old Jul 27, 2016 | 10:49 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
Please post a link to where you got this information.
