Blend Mount and Mirror Tap
Old Jul 31, 2016 | 12:14 PM
GTVETT's Avatar
GTVETT
Default Blend Mount and Mirror Tap
Has anyone used the Blend Mount radar detector holder as well as the Mirror Tap power supply on the C7 yet? If so what are your results? Does the mirror stay steady? Does the Tap work?
What detector did you use?
Old Jul 31, 2016 | 12:18 PM
bigsapper's Avatar
bigsapper
Not to sound like an ***, but did your even try searching?
Old Jul 31, 2016 | 12:40 PM
dvilin's Avatar
dvilin
Yes, hundreds have used blendmount with mirror tap power. No issues, most use Escort, Valentine or Beltron detectors. I have this setup with the Escort 8500 detector no problems with mirror shake, etc.
Old Jul 31, 2016 | 01:46 PM
Kracka's Avatar
Kracka
I have both for my Passport 9500, great setup!
Old Jul 31, 2016 | 02:12 PM
Millerrock's Avatar
Millerrock
No shake here, works great, I use a valentine one
Old Jul 31, 2016 | 03:25 PM
nhz51's Avatar
nhz51
Just installed both yesterday. Works great and no problems.
Old Jul 31, 2016 | 09:32 PM
Cromagnum's Avatar
Cromagnum
Did mine the other day. 9500ix, but recommend thr longer arm. No shake. No GPS issues.
Old Jul 31, 2016 | 09:43 PM
kaufmansm's Avatar
kaufmansm
Works fine with my max 360
Old Jul 31, 2016 | 09:50 PM
Former USMC's Avatar
Former USMC
Greetings,
I did not. I simply mounted my radar and laser (if it detects, you're caught) detector just left of the steering wheel and hardwired the detector to the fuse box in rear compartment.
Not really sure if mounting the detector 24 inches higher and to the right will make it more accurate. Mine pretty much detects everything including Audi's.
Semper Fi
To Blend Mount and Mirror Tap
