Loading C7 in enclosed trailer
My rear door opens up, and I pull out two ramps to load the car like most open trailers, and I have had no problems loading my C6 Z06, ZR1, or my new C7 Z06 (I brought it home to Daytona from Museum delivery in the trailer, as well as hauling it up and back to the VIR HPDE the end of June).
However, I can comment on the tie down procedure most of us use. You can see below that I use the most common tie down method of hooking straps into the frame:
The tie down points in the frame are the exact same oval holes that you use to put your jacking pucks into - there are two on each side. The best hooks are the "T-hooks" that you can get at Northern Tool or many other sources:
I assume that if you are considering tire bonnets that you have e-track rails in the floor of your trailer. If you have e-track rails then you have more options.
The tire bonnets hold the car in place, but it will still bounce on the suspension slightly. I like the T-hooks in the frame because they pull the frame down just a bit and hold the entire car tightly in the trailer. I've got about 10,000 miles pulling my Vettes in my current trailer with the T-hook and strap method with no problems at all.
Last edited by Steve Garrett; Aug 3, 2016 at 07:32 PM. Reason: No need to re-quote the OP, especially if you're the next person posting.
I would have preferred to use those hooks in the frame.
And you can see the "Escape Door" I have on the left side of my trailer so I can easily just open the car's door to climb in/out of the car while it's in the trailer. I can also very easily reach the left side front and rear holes in the frame, so I really only need to attach/clamp the right side straps before loading the car.
I'd never get another enclosed trailer that didn't have an escape door on the left!
Last edited by Steve Garrett; Aug 3, 2016 at 07:33 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
I trailered my C7 to Carlisle, and had a difficult time getting the car in and out of the trailer....until I got some race ramps to put under the ramp. Made all the difference in the world. I would highly recommend getting a set. They even make them specifically for use as trailer ramps.
As far as strapping the car down, I concur that the T hooks are the way to go. Worked perfectly for me and the car never moved during 4000 miles round trip in the trailer.
Happy trailering.
