Gas
St. Jude Donor '12
Gas
what type of gas do you use? I need to top off my tank, I dont know what the dealer put in the car. But I was in town and filled it up with high test. My main question is Do you guys think as long as its high test does it matter what company it comes from? Last time when I was in town I went to shell oil.
On my 2 c-4s I did get the best mileage from the mid grade.
What we think does not signify. The GM owners manual specifically calls out premium gasoline. If you use a lower octane fuel, the engine will dial back spark advance to reduce possible damage from detonation. Don't make your engine do that.
The best fuel comes from gas stations that are part of the Top Tier program, and guarantee to use an additive package that exceeds the minimum EPA detergent requirements. Go to http://www.toptiergas.com/retailers/
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
I only buy from brand name or big chain dealers and only buy 93 octane. I believe the C7 is more forgiving than the C5 where it was best to use Chevron or Shell for the additives.
I never use independent dealers. I know all gasoline comes from the limited number of refineries. However, the larger dealers tend to take better care of their equipment at the stations and, in this area, they don't cheat on the octane. Some independents here were caught mixing their premium with lower octane.
Some fuels not on the Top Tier list may contain equally effective additives, but the fact they are not on the list just means they haven't bothered to have their fuels certified. Chevron, Shell, BP, Exxon-Mobile, Costco, etc. are all Top Tier, but there are many others.
If you stick to buying premium fuel from big-name suppliers, you're getting the best fuel available.
Get the best gas available. Why spend 70K on a car and worry about pennies.
lpabsolute (08-09-2016)
I've tried a couple tank fulls of Walmart 93 ethanol blend, but my car seems to prefer 91 non ethanol blend from a regional grocery store chain (Hy-Vee)
If traveling, I try to go for whatever hi octane I can get. Lots of stations around here only got 87 and 87 ethanol blend, so it's best to start looking for gas a bit before you're desperate.
Gasoline certified as "Top-Tier" has nothing to do with emissions or EPA requirements. It is a standard that was developed by various manufacturers (Audi, BMW, GM, and others) to specify detergent and other additives necessary to prevent the build-up of engine deposits and keep the valves and other internals free from coking and carbon deposits over the long-term. You won't notice the difference in a single tank of gas.
Control of Air Pollution From Motor Vehicles: Tier 3 Motor Vehicle Emission and Fuel Standards
A Rule by the Environmental Protection Agency on 04/28/2014
Several major gasoline marketers have adopted Top Tier for their gasoline. It is widely accepted that conformance with the Top Tier IVD and FID control testing requirements is more challenging than complying with the standard EPA IVD and FID testing requirements. Accepting IVD/FID test data that complies with the Top Tier requirements in place of the standard EPA IVD/FID testing requirements will provide significant savings to industry from reduced deposit control testing while maintaining the emissions benefits of EPA's gasoline deposit control program. These changes are being codified in the regulations at §§ 80.161(b), 80.163(a)(1)(iii), 80.164(a), 80.165, 80.167(a), 80.176, and 80.177.
Show citation box
The comments we received were in favor of the proposal to accept test data that demonstrates compliance with the Top Tier program as alternative compliance data under EPA's deposit control program. Chevron stated that their extensive experience with deposit control and related vehicle/engine performance testing, combined with the vast body of technical literature on the subject, shows that compliance with Top Tier IVD/FID requirements provides improvements in emissionsand performance compared to fuels with deposit control additive levels that merely meet EPA's deposit control requirements.
Show citation box
when I first bought a car (it was a truck) with a direct injection engine I was amazed at how much power it made and still got pretty good mileage. I wondered about what possible downside there could be from this seemingly miraculous technology. In reading around the web I saw references to DI engines having a problem over time with carbon buildup on the back side of the intake valves. apparently in older engines the fuel air combo flowing over the valve helps keep it clean and injecting the fuel directly into the cylinder loses that effect. AAA recently released a report saying you should only use name brand fuels in direct injection engines.
http://www.aaa.com/AAA/common/AAR/fi...ull-Report.pdf
see bottom of page 9
I'm speculating that the detergents in the fuel help solve this problem
this is a lot of speculation on my part but I stopped buying cheap gas from the no-name gas stations
Dave
Dave
5000 miles a year at 17mpg =300 gallons- and using a 10 cent a gallon savings equals a whopping 30 bucks for the year-20 cent saving doubles that to an astronomical 60 buck savings for the year.
Received 3,447 Likes
I use Chevron, I live in Oregon and we have 93 octane. In the states south of here it is 92. Not a fuel expert. Don't know why it is lower in Ca and Az.
The doc you published has nothing to do with the reason the Top Tier standard was developed, which was NOT for emissions reasons. It was to reduce warranty claims and customer angst due to carbon-fouled engines.
What you posted simply says the EPA will accept the Top Tier certification standard as an alternative to their testing program, but it has nothing to do with why the standard was originally developed. The 2014 EPA rule change means fuel suppliers will no longer have to perform the EPA test, if their fuel is Top Tier certified. However, Top Tier long predates EPA requirements.
In the 80's the problem got so bad for some manufacturers, that they recommended an additive be added to fuel to address the carbon deposit issue. I remember well following BMW's recommendation to add a bottle of "Techron" (manufactured by Chevron) every other fill-up in my BMW 325e. Eventually, BMW and manufacturers and agreed to develop a standard (Top Tier) whereby all the appropriate additives would be added to gasoline. Shortly after, Chevron began adding Techron to their fuel so that the customer no longer had to.
JerryU (08-08-2016)
E-Ray, 3LZ, ZER, LIFT
Received 9,657 Likes
Per the manual I also use the GM gasoline additive at each oil change since I don't use Top Tier all the time. Figure it might help the injectors and it definitely helps with buildup on the fuel sender. Folks have reported this issue and getting it replaced is costly. In fact some have reported their dealer solved the fuel level sender issue with several bottles of that same GM additive (part number is in the Owner's Manual, I buy from Amazon.). Charged them ~$100.
The issue is sulfer in the gas, which all have to some degree, depends on where the dinosaur died and the oil that the gas was refined from!
You want a gas with a good detergent additive and using a top tier gas assures you'll do that. I had to have the valves on a BMW blasted to remove deposits because I was using gas without the right detergents to keep the engine clean. It met the octane requirements and that's all I paid attention to. This was back in the 1980's when BMW developed a test to determine how well a gas cleaned engines.
Received 19,440 Likes
'20-'21-'22-'23-'24
I would use premium grade from a known company. That's just my preference.
