IPC USB Plug
Old Aug 20, 2016 | 03:24 AM
whitehooptie's Avatar
whitehooptie
Default IPC USB Plug
What is the USB connector for on the back of the instrument panel?
Old Aug 20, 2016 | 05:20 AM
kitesurfer's Avatar
kitesurfer
flash drive, phone...
Old Aug 20, 2016 | 07:35 AM
Frodo's Avatar
Frodo
The USB connector is a port into your infotainment system
Old Aug 22, 2016 | 11:23 PM
Bavaria's Avatar
Bavaria
My Garmin GPS is connected there. Works perfectly.
Old Aug 23, 2016 | 12:36 AM
whitehooptie
I think that there is some confusion on the question I'm asking. I'm referring to the instrument cluster USB connection. If you remove the instrument panel from the vehicle, on the back next to the standard connector that has the speedometer wire, the data bus, and whatever else, there is a mini B USB connector there. What does that go to?
To IPC USB Plug
