Bad Gas Distributed Questions
Oklahoma only runs 91 octane and one of the places I got gas from was on the list of sites given that gas. I already drove 80% of that tank since because I wanted to spend my days off cruising. I know of the possibilities of damages to the injector due to this bad gas. What else can I do or should I be looking for? This is a first for me.
No single delivery semi tanker holds 450,000 of gasoline, so that means the ethanol was added to some 65-70 semi tanker trucks.
Go to pure-gas.org
Then click on "map"
Then zoom in on your city/state
Then click on a blue teardrop near where you live to see the brand, the street address and the octane. There a lot of stations that sell ethanol free gas in Oklahoma.
http://www.jackssmallengines.com/jac...fdy6gqodrmceyg
If you have 30% ethanol that is VERY hard on the plastic and rubber and I would recommend getting it documented. The manufacturer will simply say they cannot guarantee their engines and systems to operate properly at greater than E10.
Fuel lubricates the pump and injectors as well.
In the short term your fuel trims will go high, but should return to normal as soon as the proper fuel is added.
If your car is new, you don't have the worry of the ethanol breaking free accumulated dirt, but you do have the concern for rubber and plastic fuel system components being affected. Alcohol is a solvent. I worked with many dealers in Brazil who regularly got 20-25% alcohol and in the short term we didn't see any physical damage but the motorcycles needed new EFI mapping to run properly.
If your car has a lot of miles on it, the higher solvent can break free deposits that have settled in for the long term, but that's not too common if you've been using top tier fuels from name brand stations.
This is unfortunately a wait and see kind of situation, but having proof of what was in your tank will either set your mind at ease or allow you to file a legit claim.
