Range Technology
Old Sep 4, 2016 | 01:34 PM
Bob Nelson's Avatar
Bob Nelson
Default Range Technology
Has anybody had any luck leaving the module plugged in all the time?
I am plugging mine in after the car starts and unplugging it when I shut it off. When I left mine plugged in at the start, it started funny and had a CEL with 10 codes. It would not shift higher than 4th gear.
Old Sep 4, 2016 | 01:44 PM
Benwish's Avatar
Benwish
I did not get any codes, but was concerned about the s all amounts of amps it draws.
I got this
https://www.amazon.com/Tonsiki-Femal...ds=obd2+switch
To shut it off after a ride and to prevent in/out on the obd2 port.
Old Sep 4, 2016 | 02:09 PM
cam30era's Avatar
cam30era
It sounds like yours might be an older one with out of date software. I believe that Range is offering a free software update/exchange. Check their website.
Old Sep 4, 2016 | 04:12 PM
Beezvette's Avatar
Beezvette
Maybe this has been resolved with the software update mentioned above. When the C7 came out, a lot was written about the Range option on this forum. One member bought one and had issues like you mention. The other issue was that it was a constant power draw. For those two reasons i opted not to get one.
Instead I just use the paddle shifters. Eliminates the whole V4 issue and is fun. After owning the car for 2 years (8K miles) that approach has worked out well.
Edit: Just read about the switch; that was not available (or at least i could not find it) when i was looking. It would help but still risky in terms of remembering to switch it off. Such a pain, why can't we have a button on the dash provided by GM???
Last edited by Beezvette; Sep 4, 2016 at 04:15 PM. Reason: Just read about the switch
Old Sep 4, 2016 | 04:40 PM
grandpawmoses's Avatar
grandpawmoses
I bought one last fall and haven't had any issues with it. I leave it plugged in all the time unless I'm after gas millage. It does have a small current draw But I do keep the Vette on a Battery Tender anyway.
Old Sep 4, 2016 | 05:22 PM
Streetrod782's Avatar
Streetrod782
Had the same issues until I had it updated and no problems since then, However if you leave it in for about 3 days your battery will be dead. Did it twice....
To Range Technology
