Winter Storage Checklist
Old Sep 6, 2016 | 01:15 PM
bcegaleace's Avatar
bcegaleace
Default Winter Storage Checklist
Bought my vette new in April 2016. Plan to drive until the weather really turns. I've read a few threads about winter storage, with advice that is all over the place. My plan is to:
1) complete detail... wash, clay, machine polish and wax the exterior. Clean the inside thoroughly.
2) put baking soda in the car to grab any odors that might occur.
3) park in my garage with a fitted, good quality car cover.
4) add a fuel stabilzer
5) i'll probably get an oil change before, it is close to due anyway
6) inflate tires to 35-40psi
Any other suggestions? I'm hoping to run it as deep into the year as possible... at least until it's consistently cold, or when the snow flies.
Old Sep 6, 2016 | 01:20 PM
Foosh's Avatar
Foosh
My winter plan is:
1) When snow accumulates on the roads, wait until it melts.
2) Keep driving throughout the winter.
Old Sep 6, 2016 | 01:22 PM
bcegaleace's Avatar
bcegaleace
Originally Posted by Foosh
My winter plan is:
1) When snows accumulates on the roads, wait until it melts.
I've considered it, but I have a nice AWD car for the winter and I'd rather just keep it off the road once it gets nasty. I'm in Massachusetts, and once it snows, the roads get so crappy with salt/sand, etc., that I'd rather just keep the vette in the garage.
Old Sep 6, 2016 | 01:31 PM
Foosh's Avatar
Foosh
It's the same here, and we also have a Jeep, a 4 X 4 truck, and a Mercedes 4MATIC, but salt is not an issue on a non-metal car w/ an aluminum frame. XPEL Ultimate will take care of the sand issue.
There are plenty of nice, sunny, winter days with daytime temps above freezing. I'll keep enjoying the C7 on those days.
Old Sep 6, 2016 | 02:04 PM
Dr Jay's Avatar
Dr Jay
Same here in northern VA. I have had my C7 through two winters now and have enjoyed the days you describe. I even drive it in 20 degree weather (carefully) with no ill effects. Tires held up fine (non Z51)
Old Sep 6, 2016 | 02:47 PM
Zjoe6's Avatar
Zjoe6
Moderator
I bought a thick plastic tarp at Home Depot to put on the garage floor. Keeps the humidity off the bottom of the car. I actually tuck it into the bottom of my cover to give it a full wrap.
I also use a Battery tender.
Old Sep 6, 2016 | 03:11 PM
Larry/car's Avatar
Larry/car
My winter plan is:
Good plan. I don't take mine out to crud it up, don't park it either. Last winter the car sat less than a month.
Old Sep 6, 2016 | 03:41 PM
dvilin's Avatar
dvilin
Suggest hooking up to a battery tender.
Old Sep 6, 2016 | 04:10 PM
jasonsbiz74's Avatar
jasonsbiz74
I wont be driving mine during the winter either. I would either take the battery out and keep it on a charger or put a trickle charger on it inside the car (depending on storage spot). I'm not sure on the oil change before winter but definitely at the beginning of the season for sure. I do the same thing with my boat. Clean, wrap put away then we do the spring "start up" once the weather breaks which includes Clean again, oil change and in wrap. I hate Ohio winters !! Ugh
Old Sep 6, 2016 | 04:24 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Gang, Don't forget something to discourage little critters like mice from setting up housekeeping in your stored Corvette.
I know it's an old story, but my friend in New Hampshire lost her Porsche Boxter when mice ate enough of the wiring harnesses to cause her insurance to call it a total loss. It can happen.
Old Sep 6, 2016 | 04:34 PM
Foosh's Avatar
Foosh
Yes, cars that don't run much sometimes suffer far more damage than those that routinely stay on the road. Rodents eat, seals dry-rot, internal parts don't stay lubricated, and so on.
When some see a used car from 3-10 years old averaging less than 1000 miles a year, they often think that's great. I would walk away.
Old Sep 6, 2016 | 04:51 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
All of the above plus....
Start it up and run it up to temp every 3-4 weeks.
Old Sep 6, 2016 | 04:54 PM
Runner717's Avatar
Runner717
Had a 40 ft 2005 diesel searay. For 8 yr, they recommended oil change before storage,run the engine for a while and put her to bed,everyone in the marina would do the same,I have the oil changed in my 2015 Z51 in late fall,stabilize,battery tender,cover,and up on lift.See her in late March if it worked for the boat I'm sure it's good for the car
North Jersey
Foosh's Avatar
Foosh
That may help some, but suspension and transmission parts need to move too.
Old Sep 6, 2016 | 05:33 PM
vettman96's Avatar
vettman96
No such thing in Vegas
Old Sep 6, 2016 | 05:39 PM
dvilin's Avatar
dvilin
Absolutely not, do not start it unless you intend to drive it.
Old Sep 6, 2016 | 05:50 PM
user051728's Avatar
user051728
Mine goes away in October and comes out in March. The salt isn't my primary concern it's cold temps on the tires.
I wash, wax, clean the entire car. I then fill the tires to 35 psi to account for the 1 psi a month loss (I have flat stoppers to keep the wheels round). I change oil in spring. I use a battery tender, and I cover the car. Rodents I keep out of my garage and so I worry less about those, but if you live in an area with rodents, set traps. I use desiccant bags in the interior to suck up moisture. That's about it.
I usually only have mine away 5 months if I can help it. 6 is considered a long Winter.
To Winter Storage Checklist
Old Sep 6, 2016 | 05:52 PM
user051728's Avatar
user051728
Depends on age of the car. Modern cars can run on about 2000-3000 miles a year and stay in good working order.
Old Sep 6, 2016 | 06:19 PM
Maxpowers's Avatar
Maxpowers
I pick up my second set of wheels with winter tires next week. Unless there is deep snow, any RWD sports car drives just fine in the cold with the right rubber.
Old Sep 6, 2016 | 06:38 PM
pbergmann's Avatar
pbergmann
Boy I sure would not do that.... all your going to do is get the exhaust soaked with moisture, engine choked with bypass fumes then you turn it off and it sits.... not what I would want!!!!
Once its off for the season... its off!!!!!
But here in AZ my season is just starting... gotta dust off the cars and get them out!
