Bad battery
Old Sep 11, 2016 | 01:24 PM
Neil Baker's Avatar
Neil Baker
Default Bad battery
Anybody have a bad battery? 2016 700 miles Z51 voltage not going over 12.9 volts on drive this morning! Usually 13.8 to 14.1 volts!
Old Sep 11, 2016 | 01:26 PM
juanvaldez's Avatar
juanvaldez
Maybe the battery if fully charged.
Old Sep 11, 2016 | 03:08 PM
Glen e's Avatar
Glen e
The car has smart charging. Someone will explain it in more detail but the bottom line is it only charges much that needs to , based on the strength of the battery.
Old Sep 11, 2016 | 05:11 PM
Neil Baker's Avatar
Neil Baker
I love this forum! Yes, I have been reading and learning about how smart this car really is. The smart charging system explains why on my joy ride this morning with roof off and no AC the battery voltage stayed at 12.9 volts. When it got too hot for my wife, (we are in Florida and it was 94') I stopped and put the roof on and turned on the AC to 60 degrees auto and the voltage went to 14.1 Guess this system was working just the way it was designed! I'm very happy!! Thanks for your comment!!
Old Sep 11, 2016 | 06:13 PM
One more thing learned about the C7.
Old Sep 11, 2016 | 06:40 PM
NSC5's Avatar
NSC5
Neil, I first saw your post in the tech forum and answered in more detail there. Here is a copy of that info but to summarize what you are seeing is perfectly normal.
Copied from my other post in the tech forum....
There is nothing wrong or abnormal with 12.9 volts in a modern GM vehicle with the engine operating. The alternator output level commanded is part of the fuel efficiency strategy and also a way of increasing battery life through heat/overcharge management. When the system senses the battery is low it will command higher alternator output via greater field excitation resulting in higher system voltage and a faster charge rate but once the battery is at/near full charge the voltage will ramp back to the mid to high 12 volt range. My 2016 Z06 behaves this way as does my 2014 Cadillac ATS and my 2008 CTS was the same.
If you monitor voltage you will see even greater swings on a long trip as it goes from heavy charge to a very light system maintenance level.
To Bad battery
