HELP--DIC display setting
Old Sep 12, 2016 | 06:46 PM
gbjerke's Avatar
gbjerke
Default HELP--DIC display setting
Where to go if you have any question??? RIGHT HERE! Can't count the times I have had questions and every time you guys stepped and had a solution.
My normal display shows the speed, distance to empty, V8 or V4 etc.
Same thing today when I went to gas up. Started up and the display showed the MPH but the rest of the screen only showed the XM station I was on, the song and the artist. I tabbed every which way to try fix with no luck. On my usual display I could hit the down button to show oil life remaining, one more tab down showed the tire pressures etc. Now when I hit these buttons it merely changes the XM station to the next one.
This explanation may not be very clear but am hoping for an answer.
Thanks in advance.
Old Sep 12, 2016 | 07:40 PM
mpuzach's Avatar
mpuzach
With your engine running, refer to the left / right / up / down arrows on the right spoke of your steering wheel:
  1. Push the left arrow button.
  2. Referring to the list that then appears, push the up arrow button until "Perf" is highlighted.
  3. Push the center button on the right spoke of your steering wheel.
  4. Push the right button.
That oughta do it.
Old Sep 12, 2016 | 09:00 PM
RonC7's Avatar
RonC7
See the link for DIC display navigation.
Lots of good info in the Sticky Notes!
https://www.corvetteforum.com/forums...chy-chart.html
Ron
Old Sep 13, 2016 | 06:05 PM
gbjerke's Avatar
gbjerke
That oughta do it.
A HUGE thank you mpuzach!
Worked like a charm. Now, all I have to figure out is what button I accidentally pushed to give me this problem in the first place.
Conclusion--tech challenged old farts have no business in owning one of these Vettes....Oh wait, I take that back as I can always get answers on this forum.
To HELP--DIC display setting
