Adding Inside Auto-Dimming Mirror
Old Sep 19, 2016 | 04:43 PM
Zaphod B's Avatar
Zaphod B
Default Adding Inside Auto-Dimming Mirror
The only feature that I would really like to have from the 2LT group is the interior auto-dimming mirror. Is it an easy add - is the wiring to the mirror the same on all 3 trim levels?
Thanks!
Old Sep 19, 2016 | 05:00 PM
Mister Big's Avatar
Mister Big
It's an easy install and the wiring already exist. I did it to my 1LT and it took all of 5 minutes.
Old Sep 19, 2016 | 05:09 PM
vbdenny's Avatar
vbdenny
I didnt know the auto dimming mirrors werent standard. Cost much?
Old Sep 19, 2016 | 05:14 PM
Mister Big's Avatar
Mister Big
I believe it cost me less than $120.00. The GM part number is 23101468.
Old Sep 19, 2016 | 05:30 PM
Zaphod B's Avatar
Zaphod B
Thanks, Mister Big!
Safe to assume that that part is the same across all '14 and on years, and all models?
Old Sep 19, 2016 | 05:57 PM
HDBADDOG55's Avatar
HDBADDOG55
Would you be so kind as to provide me with a "how to" walk through on swapping out the mirror. Thank you in advance.
Old Sep 19, 2016 | 06:04 PM
Mister Big's Avatar
Mister Big
Here are the instructions I got from another forum member:
"You need a small pry tool or a very small flat head screwdriver to remove the plastic cover that is on the back of the mirror "neck". Once you carefully remove that you will see the wiring harness. Give it a gentle tug to give the wires some slack. Then disconnect the wiring harness to prepare for mirror removal. You will see two openings on either side of the mirror neck. They are small so here is where the small skinny screwdriver comes into play. You insert the screwdriver through the two holes and then twist the entire unit counterclockwise I believe like 45 degrees. Then the whole unit is free from the top of the car. If you have the new mirror already you can look at it as there should be some markings on it showing where the small screwdriver goes thru so you know you are using the right holes to perform this. Putting the new one on is just reversing the steps."
Old Sep 19, 2016 | 06:14 PM
Mister Big's Avatar
Mister Big
I'm not sure if it's the same for all model years so you should ask the vendor that question. Mine is a '16.
To Adding Inside Auto-Dimming Mirror
